Silver solder or braze to chromed steel
Brian Wood29/04/2017 17:24:33
2742 forum posts
39 photos
Has anyone any experience to offer with making a joint of this kind to a square, shiny chromed steel collar, please?
​This is a Remap job for a head support on a wheelchair, the material being attached is stainless steel, grade unknown, but I don't think the joining process is fussy about that.
Thank you
JasonB29/04/2017 17:30:20
Think I would be inclind to grind off the chrome in the area to be soldered with a Die grinder or dremel then solder with HT5 or Tenacity 5 flux which you will need for the stainless. The heat may well discolour the surrounding chrome.
Speedy Builder529/04/2017 17:39:05
2878 forum posts
248 photos
Did you mean 'Chrome steel' or chromium plated steel. If plated, I would remove the plating first as per Jason's post. If the silver solder took, it would eventually peel the plating off. If its 'chrome steel', as per Jason, use tenacity 5 and silver solder.
BobH
Neil Wyatt29/04/2017 17:40:36
19226 forum posts
749 photos
86 articles
A bit of googling suggests you can silver solder to chrome, but if the plating is poor the joint will fail sooner or later.
If you have a drilled a socket into the unchromed metal and get penetration into that, you can probably get away with it.
Brian Wood29/04/2017 18:01:48
2742 forum posts
39 photos
Gentlemen,
​Thank you for your quick replies, it is a Chromed collar of unknown integrity so I will remove the chrome in the joint area. I don't think discolouration of the rest of the chrome will matter much, although I will polish where I can afterwards.
​This approach will save me a great deal of fabrication work that the suggested design was likely to require and I think it will be stronger for the intended purpose too
Kind regards
​Brian
Edited By Brian Wood on 29/04/2017 18:03:11
