First of several
Mystery tools
peter blair31/03/2017 14:39:46
34 forum posts
25 photos
Here is the first in a group of tools that I hope you guys can help me identify.
It was collected in a box of the items from a garage sale.
It is a sort of razor blade shape but quite thick on the back comes with a small hinged lit tin. The tin is slightly shaped the same as the 'blade'.
Speedy Builder531/03/2017 14:47:47
2878 forum posts
248 photos
It is a blade, in which case it was from a "Rolls Razor" for shaving. I think the script says that, so not too much of a mystery , and the case was for portability. I have seen them as a set of 7, one for each day of the week, and they came with a sharpening machine which was an oil stone on one side and leather strop on the other. The section is much the same as a cut-throat razor, but much (well a little bit) safer.
BobH
SillyOldDuffer31/03/2017 14:48:12
10668 forum posts
2415 photos
Looks like the spare blade of an early type of safety razor. The razor came in a box with an oilstone. The handle and blade holder are hinged to make sharpening easy. I have one made by Rolls Razor somewhere.
Cash prizes I hope!
Doh! Speedy Builder is speedier than me.  Perhaps we could share the prize?
Edited By SillyOldDuffer on 31/03/2017 14:49:19
John Flack31/03/2017 14:54:43
171 forum posts
Hmmmmmm... It looks like a holder for the old ROLLS(not Royce) blades my dad used to use in his rolls razor.
If it's hall marked I pass.
peter blair31/03/2017 23:58:50
34 forum posts
25 photos
Ok so you guys really are good!! I did think it might be razor blade but thought it might have something to do with early drafting or drawing.
Here's your next test. Almost looks like a 'nibbler' of some sort the metal protruding from the front has a notch but I can's even guess what the two L shaped guides/brackets are . . .
img_1625.jpgYou guys are GOOD!! I
Bazyle01/04/2017 00:13:19
6956 forum posts
229 photos
The L brackets are just to stop your hand sliding up the handles as you squeeze because the force needed can be quite high. I have a similar one .
peter blair01/04/2017 00:14:43
34 forum posts
25 photos
Thanks Bazyle, what is it for?
Bazyle01/04/2017 00:20:07
6956 forum posts
229 photos
Well mine is a nibbler. Can't see the top of yours to be sure though. Nowadays I use an electric drill attachment one.
Speedy Builder501/04/2017 07:20:17
2878 forum posts
248 photos
Similar idea on the MONODEX cutter.
Neil Wyatt01/04/2017 09:25:12
19226 forum posts
749 photos
86 articles
Mine has 'ergonomic' ribbed plastic handles.
peter blair01/04/2017 14:42:32
34 forum posts
25 photos
Ok, sounds like you guys nailed this one as well, but tell me is a notcher and a nibbler the same? I have seen a few nibblers but this one looks like it would take a really small bite and I wondered if it might be for making some sort of small notches?
Bazyle01/04/2017 14:45:00
6956 forum posts
229 photos
Some designs are better at going round corners than others but the names are not that specific.
