David Taylor | 21/02/2017 03:52:15 |
![]() 144 forum posts 39 photos | Hi, I was using phosphoric acid as a pickle for silver soldered steel parts and also to get the mill scale off laser and water jet cut parts. It works really well. So I have been using it to clean up the inlet and exhaust plumbing for my loco during construction and it seems to clean them up well but I am wondering if anyone knows whether it will harm these metals? I could get another plastic garbage bin and fill it with citric acid but if I can just use one thing it's easier. Regards, David. |
Thor 🇳🇴 | 21/02/2017 05:22:12 |
![]() 1766 forum posts 46 photos | Hi David, Phosphoric acid is used in socalled "rust removers" on steel so if you find it works as a pickle, why not use it. I use citric acid for pickling and then dip the work in a sodium hydrogen carbonate solution to neutralize the acid before rinsing in water. Thor |
mick | 21/02/2017 08:46:38 |
421 forum posts 49 photos | Tesco lime scale remover is brilliant, just rinse it off in warm water. |
the artfull-codger | 21/02/2017 11:27:21 |
![]() 304 forum posts 28 photos | It's quite cheap on ebay, I got a gallon for rust removal & find it as good as jelonite & a lot cheaper, I had some sheets of copper stored in the workshop & where they were on the damp floor it turned green so far up the sheets so I tried phosphoric acid with a scotchbright & it came up a treat,[didn't seem to harm the copper] so I use it for cleaning brass as well. No doubt someone with more knowledge will let us know if it has any undesireable effects.. |
roy entwistle | 21/02/2017 19:37:04 |
1716 forum posts | Am I right in thinking that phosphoric acid will eat through glass ? Or am I thinking of some other ? Roy |
the artfull-codger | 21/02/2017 20:11:54 |
![]() 304 forum posts 28 photos | Posted by roy entwistle on 21/02/2017 19:37:04:
Am I right in thinking that phosphoric acid will eat through glass ? Or am I thinking of some other ? Roy Your thinking of hydrofluoric acid roy, we used it in the embossing dept to decorate glass for old fashioned pub windows along with brilliant cutting & sand blasting,some beautifull designs were made with it. |
roy entwistle | 22/02/2017 14:02:29 |
1716 forum posts | Artfull-codger Thanks, blame ano domini I know it was something nasty Roy Edited By roy entwistle on 22/02/2017 14:03:09 |
