Paul Barter | 17/02/2017 20:06:42 |
112 forum posts 8 photos | Hello all, Please may I tap the knowledgw base again? I neeed to cut a 3/8 x 10 right hand thread for a new crosslide nut on the Hobson H7 lathe I am in the process of refurbishing. Can anyone tell me the correct size of tapping drill for this thread, I have been unable to find anything on line, although one chart I found referrred to a 90% thread and a tapping drill of .2850" dia. I am not sure what the 90% relates to and whether or not this drill would give the right or best tolerance for sixty year old lead screw, although the threads on it appear to be "equally square" along the length and the presumabley unworn portions at the limits of travel. Thanks for any advice Paul |
not done it yet | 17/02/2017 20:18:22 |
7517 forum posts 20 photos | You say 'equally square'. Are you sure you are dealing with ACME thread? Or is it a square thread? Better to confirm now than get it wrong! |
Hopper | 17/02/2017 20:23:13 |
![]() 7881 forum posts 397 photos | Thread depth is half of the pitch, then deduct whatever clearance you want between the tops of the threads and the mating roots. So TPI is 10. Pitch is .100. Thread depth is .050. 3/8 minus two thread depths is .275. Add ten thou for clearance and your .285" sounds about right. The 90 per cent you refer to is the amount of thread engagement, ie there is 10 per cent clearance top and bottom of the threads so it does not bind on the OD. |
Paul Barter | 17/02/2017 20:32:27 |
112 forum posts 8 photos | Hi, I meant the tops of the threads seem equal in width and not narrower on the middle of the screw where In assume most wear takes place.Whereas the nut threads look more pointed on the crests. I must admit I have also assumed that the leadscrew will be an acme thread, it is 3/8" diameter and 10 tpi and the lathe seems to be a myford ML7 clone. Nevertheless thanks for the heads up, measure twice, cut once.........., but I keep getting it backwards! Paul Edited By Paul Barter on 17/02/2017 20:36:21 |
Ian Parkin | 17/02/2017 20:44:17 |
![]() 1174 forum posts 303 photos | Whenever i have needed to cut a female thread acme/trapisiodal I have never been able to cut with a tap I've always had to single point it before and use the tap to clean up...even in small sizes My 2p Ian |
Paul Barter | 17/02/2017 20:46:26 |
112 forum posts 8 photos | Hopper, thank you for your clear and very helpful explanation, I am much obliged. Paul
Paul Barter | 17/02/2017 21:12:27 |
112 forum posts 8 photos | Hello Ian,Thanks for your warning. I hope to use a "single pass" tap as getting a threading tool. with an acme thread form inside such a small bore will be beyond my meagre talents. Tracy tools say this tap cuts a progressive depth of cut, only cutting full depth at the end of the tap, when presumably enough material has been removed to allow the thread form to be cut to full depth.Does this seem reasonable? I have never tried to cut an acme thread, I have only used taps and dies to create threads thusfar. Paul Edited By Paul Barter on 17/02/2017 21:13:11 |
