sean logie | 08/02/2017 10:22:08 |
![]() 608 forum posts 7 photos | I'm toying withe making a new 5/8 od crosslide feed screw . Is this possible to do by just holding in chuck and live centre on the tailstock without any other kind of support. ..ie..steady rest . The feedscrew is about 12" . I'm only planning the thead part of the FS and then joining the none thread part to the new FS if that makes sense at all . Sean |
JohnF | 08/02/2017 20:58:13 |
![]() 1243 forum posts 202 photos | Hi Sean, personally I think you are pushing you luck without a travelling steady on this diameter and length ! I would use a travelling steady fitted with roller guides rather than the usual brass etc fingers. |
Hopper | 09/02/2017 00:05:10 |
![]() 7881 forum posts 397 photos | I would be looking at using a travelling steady, even if just a suitably notched piece of brass bar held in the rear toolpost (use the topslide for infeed of the tool). But you can buy lengths of Acme threaded bar from industrial suppliers at reasonable prices if you shop around a bit. Might be a way to go. |
