Optical encoder for threading
Mike the Bike31/01/2017 20:59:24
16 forum posts
I am getting a Denford Orac lathe back in working order and I am not sure if the encoder originally fitted to the spindle is satisfactory for use with either Mach3 or Mach4. If the technology is too old then what should I consider as a replacement, preferable still on the spindle rather than belt driven from the spindle.
Thanks, Mike
John Stevenson31/01/2017 21:07:48
5068 forum posts
We are just using a cheap Omron one from RS, don't have the number handy, the lathe is at work.
You only want one of this and a one slot disc as Mach3 and 4 cannot read a multiline encoder.
I can look the part number up tomorrow if you want ? tried checking past orders on the RS website but it's in a continual loop
Mike the Bike31/01/2017 21:14:17
16 forum posts
Thanks John,
That would be a great help and from what you say I guessI could use the plain back of the existing disk and just cut a slot. ?how wide a slot?
Thanks, Mike
John Haine31/01/2017 21:41:55
5563 forum posts
322 photos
On my S7 the disc is about 90mm diameter Ali and the slot about 10 mm wide, but it's pretty uncritical. So the slot sub tends about (10/3x90)x360 = about 13 degrees. If you adjusted the slot width in proportion to your diameter it should behave the same.
