Quick Question
Brian Oldford | 27/01/2017 16:59:00 |
![]() 686 forum posts 18 photos | The needle rollers on the layshaft of my machine have been very noisy for some time. I've decided to tame the row by changing them. So that I can minimise the downtime by sourcing them before I dismantle the machine, does anyone here know the dimensions or code numbers of them please? |
DMR | 27/01/2017 17:34:25 |
136 forum posts 14 photos | Brian, Search for 'Super 7 bearings" and you have the answers. Lots of good info. I found this one quite quick: which I quote: "They where purchased from Simply Bearings, Leigh, Lancs tel 01942 269837 and they are a very friendly crowd. The numbers are. major brand klnj3/4 imperial deep groove ball bearing Torrington B1212oh full compliment needle roller bearing with lubricating oil hole." You are aware that the countershaft only comes out one way I presume. Dennis
Brian Oldford | 27/01/2017 18:53:11 |
![]() 686 forum posts 18 photos | Posted by DMR on 27/01/2017 17:34:25:. . . . .
I wasn't. Thanks for that. Do I remove it towards the lever (rightwards) or towards the primary pulley (leftwards)? |
Brian Oldford | 27/01/2017 19:24:32 |
![]() 686 forum posts 18 photos | I've found an online supplier of the needle rollers at £6.50 a pair. I've also found what I think is an equivalent ball race of the KLNJ series with a ZZ sheild at a measly £1.95. Although these replacements are cheap as chips, before I order them, will any harm be caused by using a metal shielded bearing in place of what I believe to be an open one? Edited By Brian Oldford on 27/01/2017 19:25:15 |
DMR | 27/01/2017 21:26:18 |
136 forum posts 14 photos | Brian, Towards the tailstock. If you PM me I will send you the relevant early manual pages that you don't have. Cannot comment on your cheap bearings. I do know that whatever you try you will still have oil spreading about. I replaced my early clutch assembly years ago with the modern version and I can say it was definitely worth it. You have a PM anyway. Dennis |
Brian Oldford | 27/01/2017 21:53:48 |
![]() 686 forum posts 18 photos | Many thanks for all the help tendered. The only missing info is about the ball race. Any gurus lurking? |
Hopper | 27/01/2017 23:15:27 |
![]() 7881 forum posts 397 photos | Fitting a sheilded bearing in place of an open one will do no harm. In fact it might be better, keeps out dirt, swarf etc. Better quality brand name bearings are more likely to run quieter and last longer. |
Brian Oldford | 28/01/2017 08:54:58 |
![]() 686 forum posts 18 photos | Many thanks all for sharing their knowledge. |
