Where can I get Dickson T1 tool holders
simon Hewitt 1 | 30/11/2016 21:40:40 |
44 forum posts 10 photos | Does anyone know of a reasonably (read cheap) priced source for Dickson T1 (or S1) tool holders? Bigger than the Myford S00 size, smaller than the more common T2, they seem rare. Rotagrip do one **Link**, Bison at £61, I would like several so its a bit steep. Thanks in fraternity |
simon Hewitt 1 | 30/11/2016 21:45:48 |
44 forum posts 10 photos | I can answer my own question - RDG have them (Sure I have looked before) £20 each. ( or £22.45 from RDG via fleabay) Edited By simon Hewitt 1 on 30/11/2016 21:47:02 |
Chris Evans 6 | 30/11/2016 22:52:53 |
![]() 2156 forum posts | Out of stock at RDG. I am waiting for them to re stock. |
Chris Evans 6 | 03/12/2016 13:28:17 |
![]() 2156 forum posts | Simon, the T1 toolholders are back in stock at RDG. I have ordered three, I will let you know how they fit when they arrive. If they prove to be OK then I shall order some more. Chris. |
Bazyle | 03/12/2016 13:39:15 |
![]() 6956 forum posts 229 photos | Also at Chronos normally. If the next size up from Myford ones they are often called Boxford size. |
Chris Evans 6 | 07/12/2016 16:50:14 |
![]() 2156 forum posts | Simon, the T1 tool holders arrived today from RDG. They fit the Dickson post very well, only minor problems are the usual gritty threads requiring a clean and a few bruises on the securing screw squares. Excellent value I shall order a few more. Chris. |
simon Hewitt 1 | 17/12/2016 12:53:49 |
44 forum posts 10 photos | Thanks Chris. I ordered 2 from RDG and they seem fine, only used one so far, it works perfectly. I also ordered the extended pattern holder from Chronos, I slipped it onto the toolpost, it went down 2cm and got stuck, I needed a hammer to get it off again! The V slots were clearly about 0.5mm out, too far apart. I posted it back and got a refund immediately - but no comment from Chronos (Who I have used a lot and are generally excellent). Perhaps the reason that patterns are quite rare is that they are very difficult to make? |
Mick Henshall | 17/12/2016 12:58:06 |
![]() 562 forum posts 34 photos | Just make your own its not difficult Mick h |
MalcB | 17/12/2016 14:47:47 |
257 forum posts 35 photos | There is quite a lot of confusion around the T1 sizing. I have the original Dickson 73 square x 63 high on my M300. I also have a total of 17 holders mixed from standard to boring bar holders. The make of these are Dickson OEM, some Bison and a couple of Pratt. I recently bought the RDG T63 parting blade toolholder which actually dropped straight on my tool post. I actually think there may well be two sizes of the T1 toolpost, both 73mm square but two different heights to match a couple of lathe variations in centre height. When you check availability from RDG there are two different slot widths listed for the T1 being 16mm ( as per Boxford sizing ) and 20mm. All the ones on my Harrison are 20mm. So, I suspect the 16mm are for Boxford ( they were 16mm on my previous Boxford ) and maybe earlier Bantam models sizing as the later Bantam 2000's had a bigger centre height.
Chris Evans 6 | 17/12/2016 17:03:34 |
![]() 2156 forum posts | 20mm "T1" suits my Taiwanese 14"x40" copy of a Harrison M300. I have paid a lot of money for inferior ones and had to return them. RDG ones seem to fit well. |
Chris Hembry | 17/12/2016 17:46:39 |
52 forum posts 1 photos | There are indeed two sizes of T1 post, sharing the holders. Data can be found here : http://www.rotagriponline.com/datasheets/toolposts.pdf These are as supplied by Bison, also available from Cutwel, no connection, just a satisfied customer of both. There are also Imperial Dickson toolposts about...almost identical dimensions, but spares are not interchangeable without modification. |
MalcB | 17/12/2016 18:12:44 |
257 forum posts 35 photos | Posted by Chris Hembry on 17/12/2016 17:46:39:
There are indeed two sizes of T1 post, sharing the holders. Data can be found here : http://www.rotagriponline.com/datasheets/toolposts.pdf These are as supplied by Bison, also available from Cutwel, no connection, just a satisfied customer of both. There are also Imperial Dickson toolposts about...almost identical dimensions, but spares are not interchangeable without modification. Good info |
simon Hewitt 1 | 17/12/2016 18:30:45 |
44 forum posts 10 photos | As Chris says, t.1 and t.1.x, identical except the height 2 1/2" (63.5 mm) |
Chris Hembry | 17/12/2016 18:58:49 |
52 forum posts 1 photos | A genuine Dickson post should have a second hole through the post fitted with a close fitting dowel post mating into a hole in the topslide. This, combined with close-fitting centre stud bushes should prevent turning enough for manual lathes. Since I'm using CNC, I can't allow any turning whatsoever, so I've fitted a piece of square bar to the topslide as an extra backstop against the tool post...no more problems so far. The Imperial info came direct from Bison as I was needing a pair of new cam bolts. The spares currently supplied nearly fitted, but just needed a skim off the diameter to be able to fit into the toolpost holes. The hex size is also different from original. Edited By Chris Hembry on 17/12/2016 19:01:41 |
MalcB | 17/12/2016 19:02:40 |
257 forum posts 35 photos | Posted by simon Hewitt 1 on 17/12/2016 18:30:45:
Simon, are you saying the toolpost itself is trying to rotate on its centre mounting bolt whilst power parting? If so, Is the mounting bolt fixed in thecompound slide or is it held by way of a sliding type of T Nut?
thaiguzzi | 18/12/2016 03:04:42 |
![]() 704 forum posts 131 photos | Posted by Mick Henshall on 17/12/2016 12:58:06:
Just make your own its not difficult Mick h Wot he said. 17 so far and counting... |
Paul Davies 16 | 01/07/2019 11:18:08 |
10 forum posts | would a t63 toolpost be suitable for a mark 1 student? it a bit difficult getting information out of suppliers. rdg say that a t63 is suitable for bantams and chipmasters but is also suitable for lathes with 5 1/2 to 6" heights. but they haven't confirmed that it will be ok for a student despite contacting them. can anyone confirm either way? also i am sure i saw a comparison chart for the different sizes of QCTP but i didn't bookmark it and now can't find it again. |
David Standing 1 | 01/07/2019 11:31:06 |
1297 forum posts 50 photos | Paul Sizing info here: |
Paul Davies 16 | 01/07/2019 11:39:34 |
10 forum posts | thanks |
