Fuel Stove/Heater
Paul Lousick19/11/2016 09:35:38
2276 forum posts
801 photos
The latest issue of Model Engineer, No 4548 has an advertisement for a fuel stove by Machine Mart. A DIY version can be made from old cast iron brake drums from a semi-trailor or large truck. A small stove can be made from 2 drums or a larger one by welding 3 together.
The top cover plate is hinged on one side and has a cut-out around the flue. (Good for boiling a kettle). A sliding, damper plate controls the airflow and fire temperature. This one is used in our clubhouse and is mobile for when we are sitting outside.
Paul.
Anthony Kendall19/11/2016 10:13:14
178 forum posts
Needs to be developed so you can easily make toast with beef dripping, but a good start!
duncan webster19/11/2016 12:20:06
5307 forum posts
83 photos
The stove at Towyn Pendre works had horizontal holes through it, which just nicely fitted your lunchtime pie
Brian Oldford19/11/2016 18:35:38
686 forum posts
18 photos
Looks to be heavily inspired by the Romesse stoves that were installed by their thousands in signal boxes.
