William Williams 1 | 21/10/2016 16:37:52 |
2 forum posts | Hi I am thinking of buying a Harrison VS330TR variable speed lathe.Has anyone had experience of running one of these from a single phase supply using a static or rotary converter. I am wondering how the converter would cope with the change in load as you changed the speed of the machine from 35rpm to 3000rpm. The machine has a 2.2kw (3hp) main motor. Any information or advice would be greatly appreciated. Thank you. William
Jon | 24/10/2016 19:50:51 |
1001 forum posts 49 photos | Its the same as the M300 without screw cutting gearbox but with three range variable speed and should be a lot cheaper. Initially ran mine off a Transwave RT5.5KW convertor it couldn't cope with anything more than a clean up cut in mid range drove me round the bend. Will need bigger convertor or inverter but costly. 4kw invertors ok on startup in low range only. With 5.5kw convertor soon as go to mid range even with a small 5" chuck will have problems with torque and spindle slowing with cleanup cuts. If seller has a convertor or invertor look what it is and test out function in top speed range and put a cut on. If its wired in to 3ph supply walk away will cost a fortune. |
JasonB | 24/10/2016 19:58:26 |
![]() 25215 forum posts 3105 photos 1 articles | Jon, I thought the TR on those stood for "Tool Room" as they come with screwcutting gear box, not like training lathes A "T" before the number would be a training lathe eg T300
Edited By JasonB on 24/10/2016 20:05:22 |
Peter Trueman | 24/10/2016 20:56:35 |
![]() 4 forum posts 3 photos | I have a M300 with a Danfoss VLT5005 5.2KVA unit and it works perfect in all speeds. No slow start up or any overloading problems in any speed range. |
Jon | 24/10/2016 21:10:48 |
1001 forum posts 49 photos | Thought it was the training lathe I stand corrected thanks. Misleading with the TR standing for Tool Room. T is the Training Lathe have a mate with one. Looks like theres two models ones an export AA both with similar gearbox as M300's. I don't have to change a change wheel just swap two over to cover smallest to largest threading with no rearrangement of other wheels. TR have to change a 24T for a 20T or similar so always have a spare change wheel. There might be more info around on the Colchester Chipmaster equivalent made by same 600 Group sharing same parts, just make sure the variator is working or walk away. Loading will be ok William its the spindle startup from zero and keeping it there when a cut is put on. |
William Williams 1 | 27/10/2016 17:36:29 |
2 forum posts | Hello Thanks for the info - looks like I should be looking for a good Harrison M300 instead. Regards William. |
Nigel McBurney 1 | 27/10/2016 17:56:36 |
![]() 1101 forum posts 3 photos | run away from it as quick as you can,variable speed and phase converters do not like each other,I had a very good condition Colchester student with variable speed unit ,b,,,,y useless it did not stay very long in my workshop,Replaced it with a a colchester master 2500 which is a very good lathe. |
Jon | 27/10/2016 18:33:39 |
1001 forum posts 49 photos | I would still have a look William, as above see it running from an inverter or rotary convertor first. |
