Carl Wilson 4 | 19/10/2016 06:27:05 |
![]() 670 forum posts 53 photos | Hello, Could someone help me out with a query please? Need to find out what the mod or Dp is of Colchester student change wheels. Also, what is the driving feature like - key way or multi spline a large Harrison M series? Any help gratefully received, Carl. |
Brian Wood | 20/10/2016 16:08:55 |
2742 forum posts 39 photos | Hello Carl, |
Carl Wilson 4 | 20/10/2016 16:54:04 |
![]() 670 forum posts 53 photos | Hello Brian, Thank you for that. I have seen some Colchester change wheels that have the multi spline driving feature similar to the Harrison M types. I am seeking info on these gears in order to 3D print one for someone. Any advance on 14DP? Carl. |
Alan Waddington 2 | 20/10/2016 19:09:11 |
537 forum posts 88 photos | Pretty sure Later Colchesters such as the Student 1800 (which are equivalent to the M series Harrisons) are 1.5 mod with a multi spline centre bore. |
John Stevenson | 20/10/2016 19:12:40 |
![]() 5068 forum posts 3 photos | Early Colchester's, round head etc 16 DP spline bore, some 6 some 8. Later Colchester's 1.5 MOD not sure what they finished up with on the spline though. |
Carl Wilson 4 | 20/10/2016 19:45:04 |
![]() 670 forum posts 53 photos | Thank you both, Gents. I had a feeling that the later Colchesters, due to their association with Harrison via 600 Group, would have the same type of changewheels. That is to say 1.5 mod and splined drive. Looking at some gears that are for sale on ebay the spline looks the same but of course the dimensions might not be. Client was not specific about age or Mark of his machine etc. When asked couldn't help as he is away from it's location for a week or so. I had hoped to get some definitive idea before he got back but not to worry. |
Alan Waddington 2 | 20/10/2016 20:27:48 |
537 forum posts 88 photos | I've got a Student 1800, can measure the spline for you, but probably Saturday before I get chance.
Carl Wilson 4 | 20/10/2016 23:10:02 |
![]() 670 forum posts 53 photos | Alan, That would be greatly appreciated, thank you. All I have to do then is to ascertain whether my customer has an 1800... Thanks, Carl. |
Alan Waddington 2 | 21/10/2016 07:36:08 |
537 forum posts 88 photos | AFAIK the splined 1.5 mod gears fit all the Colchesters from that era. Student 1800, Triumph 2000, Master 2500. Don't know about the Mascot however, as it's a bigger and more heavy duty lathe. |
Alan Waddington 2 | 22/10/2016 18:44:21 |
537 forum posts 88 photos | Dunno if this helps Carl. It's off my Student 1800, so 1.5 MOD Shaft measures .998" over the splines, and the bore of the gear is .898" Each spline is .250" wide and the gear is .500" thick. If you were to knock any of these out i would be interested in a 56T gear. Alan. Edited By Alan Waddington 2 on 22/10/2016 18:44:57 |
Carl Wilson 4 | 22/10/2016 22:30:59 |
![]() 670 forum posts 53 photos | Alan, Massive help, thank you very much indeed. The dimensions you give make it the same as a Harrison M series type spline. A 56T can be done no bother. Send me a PM and we can sort it out for you.
Carl. |
