Small no-name miller. Anybody know what it is?
Matt Nolan 1 | 18/09/2016 23:58:31 |
31 forum posts 17 photos | A machine I bought a few years ago on ebay from a chap in Wakefield. I have used it a few times, though it is still on a trolley on the floor. I made a table specially for it but haven't arranged heavy lifting help. I really should sort that out! The rats have been at my packing polystyrene...
Does anybody recognise the make and or model? |
Michael Gilligan | 19/09/2016 00:25:20 |
![]() 23121 forum posts 1360 photos | Posted by Matt Nolan 1 on 18/09/2016 23:58:31:
Does anybody recognise the make and or model? . Sorry ... No ... But it does look well-proportioned with that substantial overarm. On appearance alone, I would think it 'inspired by' the round-bed Drummond lathe. MichaelG. |
Nicholas Farr | 19/09/2016 06:46:54 |
![]() 3988 forum posts 1799 photos | Hi Matt, it could be an early Centec **LINK** If not, it looks very similar. Regards Nick, |
John McNamara | 19/09/2016 07:16:03 |
![]() 1377 forum posts 133 photos | Hi It looks early American to me, Pratt and Whitney maybe? |
Michael Gilligan | 19/09/2016 07:49:38 |
![]() 23121 forum posts 1360 photos | Posted by Nicholas Farr on 19/09/2016 06:46:54:
Hi Matt, it could be an early Centec **LINK** .... . Well spotted, Nick MichaelG. |
Bazyle | 19/09/2016 08:38:49 |
![]() 6956 forum posts 229 photos | The table with the enclosed end to the slot and the vertical handle for the z axis are characteristic. |
Matt Nolan 1 | 19/09/2016 21:49:17 |
31 forum posts 17 photos | Thank you gentlemen. Some interesting pointers with the odd family resemblence. Nothing yet that jumps out at me as "that's it!" yet though. A clue - the start button, which you have to press and hold for a second or so for the motor to get going and then you can release it is marked with "STARTET". I don't know if that's a brand name or a foreign language word for start or power. It is not clear whether the switch is an original part or not. Certainly similar vintage. Start and stop button. I didn't photograph it as it was in too much shadow and I didn't have a light to move. |
Robbo | 19/09/2016 22:25:22 |
1504 forum posts 142 photos | Matt "Startet" is the trade name for the electrical switchgear, its found on many machines. So probably original. Beware that they may contain asbestos as an insulator, but probably not enough to do any harm unless you snort it or blow the dust out.
Edited By Robbo on 19/09/2016 22:27:12 |
Brian Wood | 20/09/2016 09:42:53 |
2742 forum posts 39 photos | Hello Matt,
Jonathan Garside | 20/09/2016 09:58:37 |
52 forum posts 3 photos | Matt Startet was a trade name of the Midlands Eleectric Manufacturing Co (MEM) of Birmingham started in the early 20th century. They made huge quantities of electric switchgear over the years but disappeared into the Delta Metal Co in 1971 and are now owned by the Eaton Corp of the USA. I cannot comment of the safety or otherwise of the switch or asbestos contained therein but would hazard a guess that no one using your mill has been killed by either. More dangers in crossing the road methinks. Restore it and use it. |
thaiguzzi | 20/09/2016 10:20:55 |
![]() 704 forum posts 131 photos | Atlas? |
Matt Nolan 1 | 20/09/2016 10:45:42 |
31 forum posts 17 photos | Atlas? Yes, again some family resemblances in images of older machines I can find on the 'net. Asbestos and no no-volt reset. I think I will survive. But thanks for the warning. Awareness is key! |
Brian Wood | 20/09/2016 11:11:28 |
2742 forum posts 39 photos | Hello again Matt,
Matt Nolan 1 | 21/09/2016 11:11:05 |
31 forum posts 17 photos | Thanks Brian, It runs fine at the moment, but does lie inactive for months at a time. When I get it up off the floor and onto a table I will look at cleaning the switch contacts. Cheers, Matt. |
roy entwistle | 21/09/2016 11:16:52 |
1716 forum posts | Matt Can I suggest that you use sandpaper rather than emery for cleaning the contacts Roy |
Matt Nolan 1 | 21/09/2016 11:31:35 |
31 forum posts 17 photos | Hi Roy, I would certainly do that if you could explain to me (and others) the reason why. I would just have used whatever fine grit abrasive paper I had around - aluminium oxide or silicon carbide most likely, or even scotch-brite type plastic foam abrasive pads and some dedicated electrical contact cleaner. What are the reasons not to use emery and to use sandpaper? Thanks and regards, Matt. |
SillyOldDuffer | 21/09/2016 11:53:39 |
10668 forum posts 2415 photos | Posted by Matt Nolan 1 on 21/09/2016 11:31:35:
Hi Roy, ... What are the reasons not to use emery and to use sandpaper? Thanks and regards, Matt. I'd be wary of using anything abrasive on a switch contact. Much depends on what the contact is made of. Some contacts are faced with an anti-corrosion layer of un-reactive metal (like Platinum), which means they get dirty rather than corroded. As Emery paper is made to remove metal it's all easy to remove the protective layer and spoil the contact. Other types of contact are much more robust but unless you know what's what I would try Switch Cleaner and gentle cleaning first. Dave
Edited By SillyOldDuffer on 21/09/2016 11:57:34 |
Brian Wood | 21/09/2016 12:00:30 |
2742 forum posts 39 photos | If I remember correctly, the contacts in those old Startet units were simple stampings of springy copper or brass strip with a flash of silver plating. I am only talking about a stroke or two to brighten the surfaces, not serious metal removal. They were built to a price. |
Michael Gilligan | 21/09/2016 12:07:59 |
![]() 23121 forum posts 1360 photos | Posted by SillyOldDuffer on 21/09/2016 11:53:39:
I'd be wary of using anything abrasive on a switch contact. ... I would try Switch Cleaner and gentle cleaning first. . +1 Try Servisol MichaelG. |
KWIL | 21/09/2016 12:08:46 |
3681 forum posts 70 photos | Emery can become imbedded in a soft surface and act as a continous abrasive, whereas other grits "scratch" the surface clean, |
