Marcher 2 cyl vertical engine
valve timing
David Chadwick 308/08/2016 08:39:12
3 forum posts
Hello all,
can any one help on how to time the valve events on the Marcher 2 cyl parallel vertical slide valve steam engine, please.
This is one of several unfinished projects, and at 69 , although the Doctor has not advised me not to download any long computer programs or buy long playing records, time seems suddenly short.
All replies gratefully acknowledged
JasonB08/08/2016 09:42:47
As it is a twin high rather than a compound you just time each cylinder as you would a single. As a starting point I would have the eccentriv leading teh crank by 90degrees plus about 5degrees of lead so 95 degrees ahead of crank total.
J
Circlip08/08/2016 11:54:15
1723 forum posts
Check your PM David.
Regards Ian.
David Chadwick 308/08/2016 12:48:34
3 forum posts
many thanks Jason and Ian (circlip) much appreciated
kind regards
David
Richard Eversdijk19/12/2016 14:57:39
7 forum posts
Dear Ian,
Is it possible that I also can have those instructions about the valve setting on the marcher engine you send earlier to another forum member?
I would be much obliged.
Kind regards,
Richard Eversdijk,
Matti Piilola10/09/2018 09:41:19
1 forum posts
Hello, I am also building Marcher and would like to get the timing instructions, thank you!
