Can anyone identify this tool?
Maurice09/07/2016 22:35:56
469 forum posts
50 photos
This beautifully made old tool was found among the tools of a recently deceased friend. The horizontal bar carrying the clamps is six inches long. The "button" on the top is cast iron. It is similar to a washer cutter that I have, but it's made to carry two blades (I assume, and a point in the square hole). Could it be for cutting rings in some gasket material? Any suggestions would be welcome.
Maurice Coxwasher cutter full.jpgwasher cutter from top.jpgwasher cutter bar.jpg
MW09/07/2016 22:48:09
2052 forum posts
56 photos
Is that based on the suggestion that the assembly would rotate from a fixed point, thereby allowing the blades to carve a radius around some material?
Michael W
Bob Stevenson09/07/2016 23:24:32
579 forum posts
7 photos
it's a brace for cutting out 'rings' of veneer.....the old veneers that were an eigth of an inch thick or more. Note that the cross bar is fitted upside down as the socket taper should be the other way. The cutters were usually stepped so that they could be reversed and then used to cut the housing edges for the veneer ring to fit into.
SillyOldDuffer10/07/2016 07:46:48
10668 forum posts
2415 photos
Posted by Bob Stevenson on 09/07/2016 23:24:32:
A good example of why I'm often impressed by the knowledge exhibited on this forum. Not only does Bob know what the tool is, he tells us that it's been assembled incorrectly!
Ady110/07/2016 11:46:50
6137 forum posts
893 photos
This place is like a roomful of Arthur Neguses, amazing
Maurice10/07/2016 16:46:02
469 forum posts
50 photos
Thanks for solving the mystery for me Bob. I was going to make replacement parts for it , based one the washer cutter that I have, (my grandfather used it to cut washers for his pump, his only source of fresh water}. I shall have to do some research, now that I know what it is, before I try. It's not even mine, but i would like it to be seen as it was. I would label it as to which parts were replaced of course.
Regards Maurice
Bob Stevenson10/07/2016 17:25:40
579 forum posts
7 photos
Maurice....interesting reference to your grandfather because the one and only time I have ever seen that tool, (and the reason I know what it is) was in the hands of my own grandfather when he was cutting veneer disks in his workshop during the early/mid 1950's. as near as I can remeber across 60 years the tool was virtually identical to that in your pics. I don't remeber seeing it before or after so assume that he borrowed it for the job. The crossbar and various cutters and pivots were kept in a canvas tool roll. I can clearly remember him showing me how it worked and that he used a flat, leather covered pivot pad held in the square taper to cut out the veneer disks.
.......i forgot about this tool for nearly 60 years but about two years back when I was 'delving' into the methods of 17th C clock makers I suddenly remembered it and came to the conclusion that they must has used a very similar tool to cut out chapter rings and clock faces from sheet brass,...possibly also the actual wheel blanks too. Actually, a tool like this would be quite useful to me now for that purpose.
mark costello 110/07/2016 17:55:58
800 forum posts
16 photos
Is anything really "new?" Maybe just forgotten then bought to light.
Tim Stevens11/07/2016 15:13:01
1779 forum posts
Is anything really new?
Well, I'm not sure, but I have never come across a reference to LED street lights in Caesar's Gallic Wars ...
Cheers, Tim
mark costello 111/07/2016 22:40:45
800 forum posts
16 photos
Well played!
