sealing small cylinder and valves
David Bothwell 1 | 05/07/2016 16:54:06 |
204 forum posts | I was wondering if somebody could advise on the best way of sealing cylinders (and valves) I bought some vey thin rubber from e-bay and thought this might be ok for fastening between the boiler and cylinder on a Minnie traction engine?. I am also aware of some other ways of effecting a seal, but could someone suggest a sealant compound |
roy entwistle | 05/07/2016 18:17:30 |
1716 forum posts | I would have thought gasket material was the answer I don't think rubber would be suitable thin cork possibly Roy |
JasonB | 05/07/2016 18:33:53 |
![]() 25215 forum posts 3105 photos 1 articles | A lot will depend on how good the jointing faces are, you could get away with a smear of Graphite Foliac or the more traditional method of thin 1/64" sheet jointing (gasket) with a smear of something like Stag or Hylomar on each side. The rest of the cylinder covers, valve chest etc on a small engine like this can be done with a liquid gasket which you should be able to get from Halfords or e-bay. The advantage of this is that it adds no noticable thickness to teh joint so parts don't have to be made with an allowance for gasket thickness. Blue Hylomar and sheet jointing here |
David Bothwell 1 | 05/07/2016 19:51:43 |
204 forum posts | Thanks very much for the useful and informative replies (and the link Jason) |
kevin beevers | 05/07/2016 21:07:20 |
69 forum posts 43 photos | would have thought shelac better than hylomar |
Bob Brown 1 | 05/07/2016 21:43:57 |
![]() 1022 forum posts 127 photos | LOCTITE SI 596 Red High Temp RTV Silicone Adhesive Sealant is good to 316 C or LOCTITE SI 5920 Copper High Temp RTV Silicone Gasket good to 371 C but there other high temp sealants. |
