Micky T | 21/06/2016 21:51:11 |
![]() 76 forum posts 29 photos | I was just wandering if the crosslide from a Myford would fit on a Grayson lathe |
Bazyle | 21/06/2016 23:11:43 |
![]() 6956 forum posts 229 photos | Do you mean crosslide or topslide? I think there would be quite a high probability but crosslides are not often sold 'loose'. Also look at Drummond parts. A starting point would be to list the pertinent dimensions on here and see if someone will add the equivalent for a few models of Myford. |
dave george 1 | 22/06/2016 10:37:39 |
59 forum posts 1 photos | Theres a guy on ebay selling grayson lathe bits type into search bar.. grayson lathe |
Micky T | 22/06/2016 18:44:18 |
![]() 76 forum posts 29 photos | I've seen the parts listed on eBay but he's not selling the crosslide just the top and the apron. At the top of my dovetail it measures 54mm and is about 9 mm high To be honest there's not a lot if anything wrong with my crosslide it fits nicely and any side movement can be taken up with the gib. The only thing wrong is the backlash on the lead screw. If it was a myford I could replace either the nut or the screw or both as their readily available. But with the Grayson the screw goes through the casting which is not replaceable and also the lead screw is 8 tpi as aposed to 10 tpi on the myford. I was wondering whether it was worth drilling the thread out and fitting the myford screw and nut or am I in for a world of hurt |
Rik Shaw | 22/06/2016 21:53:55 |
![]() 1494 forum posts 403 photos | Many years ago when I refurbed my first lathe - a Grayson - I bored out the worn cross slide thread and replaced it with an acme threaded PB bush. The thread in the bush was roughed out on a friends lathe and finished with a hardened and ground tap which I was allowed to make in a tool room in which I was working at the time. It was a labour intensive job but turned out well. I just regret that I was careless enough to lose the tap which had so much work invested in it. Rik
Bazyle | 22/06/2016 22:07:38 |
![]() 6956 forum posts 229 photos | If the screw goes through the casting then you need the saddle anyway not the crosslide. IT all looks like a copy of the Drummond. However the saddle is less likely to be a good fit on your bed and is probably just as worn as yours. There are three main areas contributing to the backlash. |
