wiring diagram wanted
powercraft 3648 25-130 no gas welder
Malcolm Begg13/06/2016 17:00:12
15 forum posts
4 photos
I have a Powercraft welder which had the rotary switch jammed, I took the switch apart and got it freed,however as you know when you take these switches apart the springs etc jump out,I got it all together no problem,however I do not have any idea as to which rotation the cams go, what I would like to know if someone has one of these switches ,is the connection between each contact for each part of the rotary switch,if I get this I was going to do a you tube video on taking it apart and putting it back together as I don't think their is one showing the different parts inside the switch.
Thanks
JohnF17/06/2016 19:34:25
1243 forum posts
202 photos
Bump, can't help but just bringing you back to the top!
martin perman17/06/2016 20:21:31
2095 forum posts
75 photos
Do the various contacts have either a numeric or alphabetic system, use a meter to check between for instance A-B or 1-2 etc, remembering to see if they are open or closed with the meter.
Martin P
Malcolm Begg17/06/2016 21:04:24
15 forum posts
4 photos
Please see attached photo of switch, what I would like to know is what connection goes to what number on the switch, the switch is numbered 0-6dscf9310.jpg
