Vic | 27/04/2016 22:24:10 |
3453 forum posts 23 photos | I want an MT2 to MT2 extension socket for the head of my wood turning lathe but have only seen tanged versions. I need a threaded end for a drawbar, can you buy them? |
John Reese | 28/04/2016 02:58:11 |
![]() 1071 forum posts | In over 60 years around metalworking I have never seen an extension socket without a tang. You could cut the tang off, drill and tap for drawbar threads. How will the tool be retained in the socket? |
Martin Connelly | 28/04/2016 09:05:45 |
![]() 2549 forum posts 235 photos | Could you drill a clearance hole through the extension and use an extended drawbar to pull the tool and extension together into the lathe? An extended drawbar should be easy to make. Martin |
Ian Parkin | 28/04/2016 09:41:13 |
![]() 1174 forum posts 303 photos | The extension then would have no extraction facility |
Muzzer | 28/04/2016 09:52:30 |
![]() 2904 forum posts 448 photos | You could get around that by threading a bolt through the extension into the tool and giving the head a smart tap - or bumping it against a solid object like a vise. You'd have to be careful drilling a clearance hole through the extension, mind. You'd probably want to drill from the male taper end otherwise you'd be trying to open up a tang slot into a bore, buried at the bottom of the taper cavity... |
Vic | 28/04/2016 10:21:47 |
3453 forum posts 23 photos | Posted by Martin Connelly on 28/04/2016 09:05:45:
Could you drill a clearance hole through the extension and use an extended drawbar to pull the tool and extension together into the lathe? An extended drawbar should be easy to make. Martin Are they soft enough to do this? |
