How does this work
Vic27/04/2016 22:17:23
3453 forum posts
23 photos
Not sure if I'm being stupid or just tired but how does the cutter advancement work on this?
There are several designs like this but I can't seem to think of the simplest way of doing it. I've made the arm and the post and even made a basic non (screw) adjustable head to check it works on my lathe ok.
Michael Gilligan27/04/2016 22:25:45
23121 forum posts
1360 photos
It looks suspiciously like the all-thread is just a decoy ... Try thinking of it as just a plain push/pull shaft.
Vic27/04/2016 22:35:07
3453 forum posts
23 photos
I'd obviously like to withdraw as well as advance the tool with the screw.
HOWARDT27/04/2016 22:36:35
1081 forum posts
39 photos
I think it rotates both at the perfect plate and the pillar. Holding the ball and the ar the all thread goes through allows the cutter to move any where along the cutting edge.
Not very well put but perhaps you get my drift.
HOWARDT27/04/2016 22:38:33
1081 forum posts
39 photos
For perfect read ptfe. Pre-emptive needs to be turned off.
Michael Gilligan27/04/2016 23:35:05
23121 forum posts
1360 photos
If all else fails ... read the instructions devil
Vic28/04/2016 10:34:39
3453 forum posts
23 photos
Posted by Michael Gilligan on 27/04/2016 23:35:05:
I know how the turner itself works, I've also made one for my metalwork lathe. I'm just unsure how the tool advances though on this particular jig. I think your first post may be correct though. If so its a bit different to other jigs I've seen.
Michael Gilligan28/04/2016 10:40:55
23121 forum posts
1360 photos
Posted by Vic on 28/04/2016 10:34:39:
With respect, Vic ... I think the instructions make that reasonably obvious.
Vic28/04/2016 10:56:18
3453 forum posts
23 photos
Having looked at the instructions ( again) it doesn't advance in the normal sense. The threaded rod is (as I think you suspected) just a depth guide for repeatability. Unlike any other jig I've seen this one sacrifices some rigidity by allowing the head to swing. I would prefer to use a fixed head. Perhaps I posted the wrong example.
This one has a fixed post.
There are several others of similar design where also ONLY the arm swings around the pivot point. The head doesn't rotate.
Vic28/04/2016 11:00:40
3453 forum posts
23 photos
It was so much easier when I made this as the cut is advanced with the cross slide!
Michael Gilligan28/04/2016 14:50:06
23121 forum posts
1360 photos
Posted by Vic on 28/04/2016 11:00:40:
Now that is much nicer !!
yes
I'm sure you could teach 'Paul Howard Woodturner' a thing or two about design and manufacture.
HomeUse29/04/2016 08:56:14
168 forum posts
12 photos
Used to use one very similar in design but built in the early/mid 40’s to turn skittle balls out of “lignum vitae” on a peddle driven lathe (lathe later fitted with electric motor)
