Single pointing a thread
frank brown18/04/2016 19:39:25
436 forum posts
5 photos
I am ploughing on making a metric collet. It. The thread on it is 14.45 mm max diam with a 1.2 mm pitch.When I view the thread through a microscope it has a 55 degrees with rounded troughs and peaks like a Whitworth.
So eventually I will make a tool that cuts the correct trough shape and angle, the question is how do I get the peaks rounded and at the correct diameter. If I just use an OD of 14.45mm when the thread is the correct minor diameter, the peaks will have "flats"on them so they will need rounding off.
Any ideas on a (cheap) way to go?
Frank
pgk pgk18/04/2016 20:04:17
2661 forum posts
294 photos
Why? Does it matter if the peaks are flat..or only slghtly rounded with scotchbrite?
Muzzer18/04/2016 21:52:05
2904 forum posts
448 photos
They are supposed to have flat peaks.
chris stephens18/04/2016 22:11:22
1049 forum posts
Hi Muzzer, all very good but he said it was Whitworth form not metric.
Phil P18/04/2016 22:33:07
851 forum posts
206 photos
Frank
Your thread angle is actually a Lownherz standard with an included angle of 53° 8'
I have based that on guessing you are making a Lorch type B collet for your Alexander/Deckel high speed milling head.
I have an original drawing of these collets, if you want a copy PM me.
Phil
Edited By Phil P on 18/04/2016 22:34:00
frank brown19/04/2016 06:57:52
436 forum posts
5 photos
Many Thanks Phil, you jogged my memory, I think it was you who sent me the drawing about three years ago (Crawford Lorch collet). Interestingly the thread form is shown with flat peaks and troughs which on all of mine, as said are nicely(?) rounded. It does simplify cutting the threads, just have to do a bit of maths to calculate the actual dimensions, as opposed to the measured ones.
Frank
