Adam Wiles | 19/03/2016 16:27:37 |
2 forum posts | Hello everyone, I've come to this forum in search of a bit of assistance. I'm looking for 25mmx25mm pressed steel channel section but am having no luck in finding any locally. (The nearest I've found is in Devon and postage is expensive). I wondered why is it so hard to find? Is there a more common substitute I should be looking for? Thanks in advance for any help! Great forum by the way! |
Gordon W | 19/03/2016 18:24:03 |
2011 forum posts | Depends on what it is for, and how long the lengths you need. For short bits I would bend it from sheet, longer lengths consider cutting the top of box section. Just quick thoughts. |
duncan webster | 19/03/2016 18:42:35 |
5307 forum posts 83 photos | Try one of the larger B&Q warehouses. They do a range of steel sections, ropunds, flats, angles, folded sections |
Adam Wiles | 19/03/2016 19:44:06 |
2 forum posts | Thanks for your advice, I shall look for a bigger B&Q. |
Chris Evans 6 | 19/03/2016 20:05:12 |
![]() 2156 forum posts | Depending on where you are I have plenty of 25x25 box with around a 2 mm wall section. |
