gavin compton | 25/02/2016 19:33:31 |
46 forum posts 27 photos | hi all bit of a werid problem (for me) i have a water tank plumbed to a little hand force water pump then to boiler with a check valve boiler fitting. i tryed steaming the boiler and found it almost impossable to raise pressure.i then noticed the water tank drained without me pumping it !!. so i blanked off the check valve and drained some water off and in 5mins or so i had the safety valve popping. so my question is should there be a shutoff valve in between boiler and pump ??? or am i doing something wrong ??
thanks gavin |
Paul Lousick | 26/02/2016 05:33:57 |
2276 forum posts 801 photos | Boilers usually have a clack valve (check valve) between the boiler and the pump or injector and an isolation valve between the clack and the boiler so it can be isolated if it is leaking steam/water back to the tank. Is the tank higher than the boiler ? Water should not flow into the boiler unless the supply pressure is higher than the boiler pressure. Paul. |
gavin compton | 26/02/2016 08:32:55 |
46 forum posts 27 photos | Hi, thanks for the reply. the top of the tank is level with the bottom of the boiler. i have a 90C clack valve on the boiler (new valve) with 5/32" pipe to a brand new hand pump (https://maccmodels.co.uk/live-steam-fittings/water-hand-pumps/3-8-ram-5-32-pipe-free-standing-hand-water-pump-front-pipe-fitti.html to tank via 5/32" pipe again. from pump out put to clack valve is about 3" rise. so yea im at a lost. thanks Gavin |
Speedy Builder5 | 26/02/2016 08:34:16 |
2878 forum posts 248 photos | On SPEEDY (LBSC design), there is a 'clack' valve on the pump and another 'clack' valve on the boiler. It sounds as if steam is passing from the boiler through the boiler clack valve, condensing and sucking a small amount of water into the boiler. Steam will once again pass the boiler clack, condense and draw water. This continual process would eventually fill the boiler ? Do you hear the clack 'rattling' ? |
gavin compton | 26/02/2016 09:00:35 |
46 forum posts 27 photos | HI thanks for the reply. the boiler does "prime" it self you can hear the water feed "sucking" when tank almost emety. i be removing the boiler clack valve today to be checking it and the pump too. think i might order some more pipe and a inline 1/4 turn valve as well. thanks Gavin |
gavin compton | 26/02/2016 16:57:55 |
46 forum posts 27 photos | hi all checked the clack valve it didnt rattle so opened it up dumped it in sonic cleaner put it back togeather now its rattling away. also pump wasnt rattling either so did the same ,so now i got 2 rattles ready to be reinstalled. would it be best to add a shut off inline while it all apart ??
thanks Gavin Edited By gavin compton on 26/02/2016 17:04:17 |
gavin compton | 29/02/2016 11:13:10 |
46 forum posts 27 photos | Hi all Ok I tried again and boiler primed again.so I blocked water inlet with rubber tube.once boiler got 10-15psi I can remove the water plug and boiler won't prime. Any ideas? I also noted the check valve does not have a spring in. I believed from some drawings I seen that there should be?. Any advice? Thanks Gavin. PS what a good safety valve? My simple spring and ball one works but fails on shut off lol |
fizzy | 29/02/2016 13:10:12 |
![]() 1860 forum posts 121 photos | Clack doesn't or rather shouldn't need a spring. Ive never seen this happen, but fitting a light spring should fix things, if you can find one to fit which wont rust. The hand pump will probably be good for over 400psi so will easily overcome the spring resistance. |
