carburetor
Mick Page16/02/2016 20:46:43
1 forum posts
Hi,help! is there anyone that can give me some information on how to source a suitable carburetor for my own design 60 degree,four stroke twin..It has a bore of 34.1mm,stroke 38mm,displacement 0f 35cc per cylinder. the inlet ports are 12mm,I havent machined the manifold yet, as I need educating on what the bore size should be. In an ideal world, the carb would be of the diaphragm type as it was designed for aero use.I did have a manifold 12mm dia through to a pattern walbro ,fired straight away assisted by drill,but had no throttle response,then as I choked it ,it got slightly better,but was obviously weak.Then I learnt about the positive/negative pressure factor on the diaphragm,for two strokes,and am left wondering if I am wasting time going down that route.
Bob Rodgerson16/02/2016 23:42:32
612 forum posts
174 photos
Mick,
diaphragm type carburettors don't work too well on four strokes. I would be tempted to use an equivalent sized carburettor as that used on a glow engine, for your size engine I reckon a Carburettor from a two stroke equivalent to .61 Cu in should work ok. "Just Engines", if you are based in the UK might be able to supply.
JA17/02/2016 09:00:34
1605 forum posts
83 photos
Posted by Bob Rodgerson on 16/02/2016 23:42:32:
Mick,
They worked very well on my BMW R65 and Kawasaki. May be they don't scale to small sizes very well.
JA
Muzzer17/02/2016 09:17:57
2904 forum posts
448 photos
A lot of (small) Briggs and Stratton engines used diaphragm carburettors. Whether or not B&S engines "work well" is a matter of debate of course...
