Checking runout
John Milligan01/02/2016 14:44:50
59 forum posts
finally at long last I have started to turn some metal on my lathe and need some advice. Have set up a dti on the lathe spindle nose and my 0.0005 indicator reads zero runout which I am well impressed with and also reads the same with a centre in the bore. Have a Pratt Burnerd tru grip 3 jaw chuck but there is a noticeable "wobble" on outer diameter when running under speed. So I chucked a piece of 3/8" BMS and using dti again got a 1 thou runout at the chuck face. I know that the BMS is not necessarily round but it looks like there is more movement than that on chuck diameter, is this normal and how do I go about checking actual runout? Regards John
Nick_G01/02/2016 14:49:48
1808 forum posts
744 photos
Forget what the outside of the chuck is doing. (within reason) It's the center bit and what it is making your bar stock do that is important.
A dead centre in the bore should show the same. ........... If it's a 'good one' smiley
Nick
Edited By Nick_G on 01/02/2016 14:51:41
John Milligan01/02/2016 14:56:29
59 forum posts
Yes the dead centre straight in the bore of the spindle was showing the same zero deviation, it just looked like the chuck was moving but there is no discernible movement when stationary. Will keep turning and see how it goes, thanks for reply, btw it's a myford super 7, John
MadMike01/02/2016 15:31:20
265 forum posts
4 photos
John as Nick says do not worry about the outside of the chuck body. To some degree ignore the measurement that you get from a dead centre fitted into the spindle, although it may be considered a starting point.
Put a piece of steel in the 3 jaw chuck and face off the front face and then turn down the outer diameter. Then check the turned outer diameter that you have created. That will tell you the true runout of the machine itself. I would suggest at least a 1.5 inch diameter bar and a turned length of around 2 to 3 inches will give you a good reading. HTH.
John Milligan01/02/2016 15:50:12
59 forum posts
Thanks, next test tomorrow! John
Swarf, Mostly!01/02/2016 15:51:23
753 forum posts
80 photos
Hi there, John,
You wrote 'Pratt Burnerd tru grip', did you mean 'Pratt Burnerd "Griptru"'?
If so, the Griptru chuck is adjustable to eliminate run-out. I guess you have to perform the adjustment every time you change to a different diameter work-piece.
The instructions should be on the web somewhere (probably lots of 'somewheres'! ). I'm sure there will be members here who can advise.
Best regards,
Swarf, Mostly!
MW01/02/2016 16:28:57
2052 forum posts
56 photos
If the chuck is attatched to a back plate its possible it hasnt quite sat in the register properly because of grit and swarf and can tighten up at a funny angle.
this obviously doesnt apply if you have a camlock, which i guess may come with its own set of problems
Michael W
Edited By Michael Walters on 01/02/2016 16:31:31
Swarf, Mostly!01/02/2016 16:32:42
753 forum posts
80 photos
Hi there, again, John,
I suggest that you have a look at this web-site: http://www.600uk.com/products/machine.asp?id=150
Best regards,
Swarf, Mostly!
Edited By Swarf, Mostly! on 01/02/2016 16:33:56
John Milligan01/02/2016 18:21:35
59 forum posts
Hi, thanks for replies, yes it's a grip tru and thanks for link so will look at that later. Have got Harold Hall's lathe work, a complete course to work through so hopefully by the end of that I will have a better idea! Didn't think I would forget so much in the thirty years I have been away from a lathe, lol John
John Milligan02/02/2016 10:15:45
59 forum posts
So back out to shed to check machine today and thought I would start from beginning, checked run out of spindle inside and out, zero deviation, no vertical or horizontal movement of spindle either, checked threads etc on chuck and spindle all clean, don't have anything guaranteed round so checked with new centre drill and unused drill in chuck and runout at jaw face is 8 thou so I am of the assumption that jaws need adjusting as its a Pratt Burnerd Griptru? This is a new acquisition for me so I don't know the provenance of machine but everything looked well treated and cared for. Don't have a four jaw at present to use and funds won't stretch either. I have taken jaws out of chuck cleaned and reassembled checking they were in correct slots and noticed jaws 1 & 2 had slight play in slots but jaw 3 was nice and "tight" is this normal before I start looking further? Thanks John
Nick_G02/02/2016 10:56:44
1808 forum posts
744 photos
Hi John,
This is what I would do.- Others with more knowledge may have a different solution.
But first let me say that that if you have a Griptru chuck and it's a good one it's a very enviable nice piece of kit. smiley
Get hold of a set of instructions for the chuck and become familiar with how it's adjustment works and how to do so.
Have a good nosey at the jaw faces. (the bits that grip the bar) and check they are even and have not become 'bell mouthed'
Then chuck up some known good round stock. Ground silver steel is good for this, but if you have none order a short length and use what you have for now. This will get you into the 'ball park' and make you familiar with the process for when the ground stuff arrives. I would order a short piece say 12 - 16mm dia.
If possible concoct an adapter so that you can put your dial indicator into the tool post at centre height. That will give a good solid ref point. Take readings from as close to the chuck as you can.
Then apply what you have learned from reading the instructions regarding adjustment. smiley
EDIT :- Also make sure the ALL mounting faces are totally clean. This includes perhaps even removing the chuck from it's adjustable backing plate to confirm this.
Nick
Edited By Nick_G on 02/02/2016 11:03:45
John Milligan02/02/2016 11:05:09
59 forum posts
Hi Nick thanks for info, yes I looked at the link above and have asked them for an instruction download as I couldn't find one on the net. Have set up dti on toolpost already but will check on the jaws as you advise and will wait for the instructions before tinkering, cheers John
Nick_G02/02/2016 11:15:49
1808 forum posts
744 photos
Try this to give to a general overview.
Nick
Hopper02/02/2016 11:24:57
7881 forum posts
397 photos
Those Griptrus are no good. Best you box it up and mail it to me.smiley
John Milligan02/02/2016 11:26:23
59 forum posts
Thanks Nick, just checked my newly purchased (Christmas present) library of Workshop Practice Series books and there is one by Tubal Cain on work holding which details the Griptru chuck, awesome! John
John Milligan02/02/2016 11:27:28
59 forum posts
Lol Hopper wink 2
John Milligan02/02/2016 15:20:57
59 forum posts
Many thanks for all your advice, have now got it to within a thou runout so will see how it goes from here, John
Swarf, Mostly!02/02/2016 17:42:10
753 forum posts
80 photos
Hi there, John,
I'm pleased to read that you've made progress. I wouldn't be surprised if, with a bit of practice, you'll be able to even improve on one thou.
I endorse Nick_G's comment regarding the Griptru chucks - they seem to command about twice the price of a standard three jaw of the same size! So, if your workshop is a garden shed, take it ( i.e. the Griptru ) indoors each evening and stow it under the bed overnight!! laugh laugh laugh
Best regards,
Swarf, Mostly!
John Milligan02/02/2016 18:22:39
59 forum posts
Yes after releasing all the adjusting screws etc it felt as if they were getting easier so I assume it's not been adjusted in a while? Lol, workshop is in a new shed I have built but I don't think I will be taking chuck indoors overnight, my good wife already has to deal with loads of my junk there, cheers John
phil burley02/02/2016 19:57:25
45 forum posts
but with all that effort why not just use a 4 jaw chuck . or is it that next time you use the griptru it will still be dead on ? regards Phil
