Help needed deciding what to get
Dan Snelling | 19/01/2016 14:58:48 |
2 forum posts 5 photos | Hi all, I have tried searching, ended up more confused. I have decided to upgrade my Boxford lathes to VFD to have more control over surface speed as well as all the other benefits that come with it. Trouble I am having is the number of different brands of inverter available. What do people recommend? Any I should avoid? Same story with the motor. I am after a 80 frame size foot mount in 1hp. Recommendations on this? UK supplier with best prices and customer support? Thanks in advance Dan |
KWIL | 19/01/2016 15:21:58 |
3681 forum posts 70 photos | Newton Tesla, very helpful and experienced at all power levels. |
Thor 🇳🇴 | 19/01/2016 17:30:03 |
![]() 1766 forum posts 46 photos | Hi Dan, I am running a TEC 3-phase motor with a Transwave inverter. It is almost 3 years old and has been working well. If I had the funds I would upgrade my small lathe to 3-phase/inverter drive. Thor |
Harry Wilkes | 19/01/2016 17:37:32 |
![]() 1613 forum posts 72 photos | Purchased my motor/ inverter from Transwave two years on more than happy with it. H
Roger Vane | 19/01/2016 17:52:43 |
108 forum posts 18 photos | Another vote for Newton Tesla. I've now upgraded 3 machines using their products and found them to be very helpful and supportive. |
Raymond Anderson | 19/01/2016 17:55:54 |
![]() 785 forum posts 152 photos | The smaller of me 2 lathes [Warco GH750 ] is powered by a Siemens 3 phase motor, and a Eurotherm Drive [Now made by Parker SSD ] the set up is now around 15 years old and has, and still is, working perfectly. Motor and Drive were supplied by Transwave. |
duncan webster | 19/01/2016 18:00:48 |
5307 forum posts 83 photos | Yet another vote for Newton Tesla, I've now done 4 machines with their inverters, the box of tricks gets smaller every time. If you ask them nicely they will set it all up for you and sell you the pendant controller. |
Mike Bondarczuk | 19/01/2016 18:13:02 |
91 forum posts 6 photos | Went with Transwave for my Myford Tr-Leva VFD upgrade and also with Transwave for a rotary 3 phase converter for my Hardinge, and in both cases the company was a pleasure to deal with. No other link apart from being a very satisfied customer. |
Martin Connelly | 19/01/2016 18:58:59 |
![]() 2549 forum posts 235 photos | Remember to get a motor that has the same RPM at 50hz as the motor you are replacing. The number of poles of a 3 phase motor give different nominal speeds. Martin |
