papflynn | 05/12/2015 19:03:21 |
19 forum posts 1 photos | My new lathe arrived. It will only run when I have the start button pressed. When I release the button it stops. The Warco faq says that it is due to the chuck guard and gear cover interlocks not closed but these are fine as the contactor energises when I operate the interlocks. Is there something silly that I'm overlooking? Paul Edited By papflynn on 05/12/2015 19:04:47 |
Emgee | 05/12/2015 19:20:52 |
2610 forum posts 312 photos | Hi Paul I would have thought with any of the safety interlocks broken the spindle should not run at all, not even "inch" in any direction. Emgee |
Bazyle | 05/12/2015 19:37:08 |
![]() 6956 forum posts 229 photos | Do you have a forward reverse handle on the right hand side of the apron that moves the bottom rod to operate a switch? the 'start' button may just prime it. edit: on a lot of these machines the emergency stop button gets it ready and puts power on the circuits but forward / reverse / off is selected by that lever on the apron. The go button on the headstock is just a jogging button not a master on. Edited By Bazyle on 05/12/2015 19:43:39 |
Andrew Entwistle | 05/12/2015 19:41:11 |
![]() 120 forum posts 218 photos | Hi Paul, the start switch is a momentary jog switch so is working as intended. As Bazyle suggests to run continuously move the lever with the red ball knob, to the right of the carriage in the required direction (down for conventional forwards direction). Andrew. Edited By Andrew Entwistle on 05/12/2015 19:47:53 |
papflynn | 05/12/2015 19:50:43 |
19 forum posts 1 photos | Thanks Bayzle and Andrew thats all it was. Just proving to you all that that I am a real newbie. I'll try not to suspect that there's something wrong in future. Cheers. |
