Roger Head | 30/10/2015 09:24:16 |
209 forum posts 7 photos | I have a very hazy memory (20 years ago, or more) of watching an old toolmaker using a diamond wheel to touch up a very smooth , very sharp tool. My impression is that the speed was not very high, and I think there was a cup for coolant just above it. A simple gravity feed with a tap so that it was little more than a trickle. I seem to recall that kerosene was used. Can anyone tell me if there is a preferred speed (i.e. high, or low) for diamond/hss grinding, and if it was likely to have been kero for the coolant? Thanks, Roger |
Ajohnw | 30/10/2015 15:02:26 |
3631 forum posts 160 photos | I found a bit of information - posted here
Kerosene ignites when vaporised so I doubt if any one uses that on a tool grinder. Suds I would have thought but I believe there are specialised liquids about for surface grinding etc. John -
Neil Wyatt | 30/10/2015 15:40:16 |
![]() 19226 forum posts 749 photos 86 articles | > Kerosene ignites when vaporised so I doubt if any one uses that on a tool grinder. I used to, paraffin or paraffin-based mixes are recommended for diamond wheels. No more hazardous than using it to cool aluminium when milling. A gently application to the diamond wheel with a small brush, but I found that HSS doesn't really cause me any problems without it. It doesn't get hot enough to generate noticeable vapour because the cuts are so tiny. Neil |
Roger Head | 31/10/2015 00:46:17 |
209 forum posts 7 photos | Thanks guys. Neil - good to know. I vaguely remember being surprised at the idea of using kerosene, but that was well before I knew anything about machining at all (I'm an EE). John - thanks for the link, looks to be an interesting thread, and I'll follow up on the links you provided there. I had another question, but I'll wait to see if I find the answer in those links first. Roger |
