Tom Davies 1 | 14/09/2015 10:40:56 |
5 forum posts | Hi I have a Super 7 fitted with a gearbox which I have owned for about 20 years+ (I have lost the invoice). I had a reason to to determine which model I have and looked for the serial no (on the front lh side of the bed) there is nothing stamped on the bed in that area. I have looked all over the lathe and cannot find one anywhere. What pointers are available to tell me what version of the lathe I have. Thanks in advance Regards Tom |
Neil Wyatt | 14/09/2015 10:52:12 |
![]() 19226 forum posts 749 photos 86 articles | Welcome Tom, You should be able to figure it out from here: www.lathes.co.uk/myford/ If you can find the serial number "While late machines had their serial numbers stamped into the front of the bed, just to the right of the gap, earlier versions in a difficult-to-find location punched into the vertical way on the rear of the bed at its tailstock end" try here: www.lathes.co.uk/myford/page17.html or here: www.myford.co.uk/acatalog/Serial_Numbers.html Neil |
Tom Davies 1 | 14/09/2015 11:02:08 |
5 forum posts | Thank you Neil Found it - Made between 1968 and 1971. Thanks again Regards Tom |
