Brush finish on Stainless Steel
Fatgadgi11/09/2015 16:51:25
188 forum posts
26 photos
Anyone out there perfected the art of a brushed finish on stainless sheet with the usual range of DIY power tools ?
I can get a great finish using scotchbrite on stainless tube in the lathe. That turns out really well.
But on a flat sheet I have only seen professionals do it with some sort of proper drum burnishing machine. Actually it was someone resurfacing a Delorean bonnet on Wheeler Dealers, which I don't have ( neither the tool nor the car).
Cheers - Will
Fowlers Fury11/09/2015 18:05:24
446 forum posts
88 photos
I've had good success using the Garyflex blocks (Craytex in USA). The blocks are substantial enough to hold in the hand and move in a linear or circular manner. They are available in at least 3 grades. Depending on the surface to begin with, start with the coarse and move to fine if you need it.
Boiler Bri11/09/2015 18:44:52
856 forum posts
212 photos
We use a machine that has a rotating drum with a 240 grit sanding drum. In the right hands we can get a good finish. No use for a large area though as you can see waves in it.
Bri
Ian Parkin11/09/2015 18:55:59
1174 forum posts
303 photos
I use discs for the angle grinder that have a fleece on them
they are called dronco discs
http://www.ebay.co.uk/itm/Dronco-115-x-22mm-Bore-Angle-Grinder-Cleaning-Fleece-Disc-Coarse-/131558858436?hash=item1ea184dec4
They are really great for cleaning matals and for polishing steels and give the brushed finish
they look expensive but last well
Fatgadgi13/09/2015 09:13:49
188 forum posts
26 photos
Thanks for the answers guys - Mr Fury, can you get a good even aesthetic linear pattern with the blocks if care is taken ?
Cheers - Will
Fowlers Fury13/09/2015 13:24:06
446 forum posts
88 photos
~Will,
My workbench top is covered with thick stainless steel, it's been in use for 40+ years and is deeply scored and dented. This morning, I've used first coarse, then medium and finally, fine Garryflex blocks on a smaarea. I used the blocks in an "up & down" motion.The area was rubbed for no more than about 20 seconds with each block. The fine grade block was only applied to the left half of the area - so that bit has had, say, 3 x 20 seconds of rubbing.
The image (hopefully reproduced here !) was taken with ambient light as flash caused too much flare. Obviously Garryflex has not removed the deep scoring in that time but the surface finish is much improved. That probably doesn't constitute an answer to your " can you get a good even aesthetic linear pattern with the blocks if care is taken", but depending on the surface you have to begin with - Garryflex ought to work OK.
Neil Wyatt13/09/2015 13:34:31
19226 forum posts
749 photos
86 articles
Garryflex is brilliant, as FF's post shows, at polishing. if you want a 'brushed' finish I would go for the dark grey flexible sanding blocks, a medium grit
Nicholas Farr13/09/2015 14:13:14
3988 forum posts
1799 photos
Hi Will, I have some of these **LINK**, they are pretty good and are impregnated throughout, but I don't know how they compare to the Garryflex ones.
Regards Nick.
P.S. no connection to B&H other than an occasional customer.
Fatgadgi15/09/2015 00:05:51
188 forum posts
26 photos
Thanks gents, appreciate the advice - I'll get some blocks and give it a go.
Cheers - Will
