Check valves
whistler28/08/2015 23:10:45
3 forum posts
What is the secret to getting stainless balls to seal in small check valves, if there is one? Are stainless balls as round as bearing quality balls? Even new purchased clacks don't seal completely.
Paul Lousick28/08/2015 23:21:50
2276 forum posts
801 photos
Give the ball a tap with a hammer to seat it into valve body. If the valve still leaks, discard the ball as it may now be damaged by the hammer blow and replace it with a new ball.
Paul.
Edited By Paul Lousick on 28/08/2015 23:23:49
duncan webster28/08/2015 23:50:59
5307 forum posts
83 photos
The seat needs to be perfectly round, drilled hole no good. Reamed or better still D bit. Having said that I use O ring seated valves, which do not leak. Anyone want the drawing send me a pm, no idea how to attach it to this site.
mick H29/08/2015 06:39:51
795 forum posts
34 photos
Viton balls work very well in small check valves. Use a ball one size greater than the stainless.
Mick
