Chris Denton | 19/07/2015 15:33:12 |
275 forum posts | Afternoon, I'm making some aluminium inserts that need to be a very secure fit in a titanium tube which is 25.2mm ID, 1.6mm wall thickness. Also looking to use bonding for lubrication on the titanium and for fixing it stronger.
Obviously it needs to be a tight secure fit, but not too tight that the titanium sticks. What sort of tolerence would you reccomend for the aluminium inserts?
Thanks. |
John Haine | 19/07/2015 16:10:20 |
5563 forum posts 322 photos | Um, that sort of doesn't make sense! Do the inserts need to be fixed in the titanium or not? And why would you bond for lubrication and fixing it stronger. Am I missing something? |
Chris Denton | 19/07/2015 16:25:29 |
275 forum posts | By lubrication I mean to help prevent the titanium galling, hopefully smoother pressing in. It's a permanent joint. |
Michael Gilligan | 19/07/2015 16:36:01 |
![]() 23121 forum posts 1360 photos | Chris, 638 Loctite on a sliding fit would be fine, I think. MichaelG. Edited By Michael Gilligan on 19/07/2015 16:36:25 |
Chris Denton | 19/07/2015 16:44:24 |
275 forum posts | Thanks, I happen to have some 638! I'm recreating these forks in the picture below, it's the aluminium dropouts at the bottom of the forks I want to fit intotitanium legs.
http://www.goatsurfer.com/images/RC30_2ndGen_front.jpg
Michael Gilligan | 19/07/2015 16:56:59 |
![]() 23121 forum posts 1360 photos | Nice looking forks, Chris **LINK** for the convenience of others. MichaelG. . P.S. ... Useful document, here
Titanium is considered inert, and aluminium only weakly active, so 638 may cure more slowly than usual. ... It does no harm to the joint strength though. Edited By Michael Gilligan on 19/07/2015 17:08:47 |
Chris Denton | 19/07/2015 17:31:34 |
275 forum posts | Ok thanks. You you still think a sliding fit? |
Michael Gilligan | 19/07/2015 19:01:59 |
![]() 23121 forum posts 1360 photos | Posted by Chris Denton on 19/07/2015 17:31:34:
You you still think a sliding fit? . Yes ... Shouldn't be any problem, and [pace, Neil] it will avoid the 'galling' that you might get with anything tighter. MichaelG. |
Neil Wyatt | 19/07/2015 20:00:55 |
![]() 19226 forum posts 749 photos 86 articles | Very retro Chris! I finally scrapped my Halson Inversions a few years ago The elastomers had become unobtainable and I'd managed to kink the tubes below the crown - too many heavy landings =:-0 Neil |
mike mcdermid | 19/07/2015 23:59:23 |
97 forum posts | The dropouts were bonded in you need a bond line thickness of maybe. 5 to. 9 for the adhesive we use Dp420 from 3m though other adhesives will give you similar properties we use 30Mpa as a minimum loctite is generally lower (low 20s) by the time you have taken material tests and type into account all materials don't achieve the highest value stated on the manufacturers literature however, often we achieve 37-48 mpa dependant on preparation, the tops where the crown clamps iirc used to crimp, titanium fork legs are substantially more flexible than the cro mo or mangmoly pace used, Edited By mike mcdermid on 20/07/2015 00:07:42 Edited By mike mcdermid on 20/07/2015 00:08:53 Edited By mike mcdermid on 20/07/2015 00:09:26 |
Michael Gilligan | 20/07/2015 00:24:44 |
![]() 23121 forum posts 1360 photos | Very interesting, Mike I bow to your wisdom. MichaelG. . P.S. ... Just found this Spec sheet for 3M DP420 |
mike mcdermid | 20/07/2015 23:36:52 |
97 forum posts | Michael don't be daft man I just worked in F1 right from the days where bonding flexures into wishbones was the norm, I'm a composites engineering type but made carbon titanium and aluminium bikes for some companies, it's like having a mastermind specialist subject, sadly mines glue, the strongest ones come from Hexel 3m is a pretty good all rounder but similar to the araldite 2014 and permabond, it's a generic mid strength toughened epoxy |
Chris Denton | 21/07/2015 00:35:33 |
275 forum posts | Posted by mike mcdermid on 19/07/2015 23:59:23:
Thanks, just realised who you are! The legs are likely to have aluminium inserts in the top down to around the brake boss area to prevent flexing and the tops getting crimped. I have a dropout made now so can calculate how much heavier these titanium ones are compared the the original steel forks! |
Michael Gilligan | 21/07/2015 15:26:25 |
![]() 23121 forum posts 1360 photos | Mike, I would be grateful for the benefit of your experience [and I suspect that others would, too]: Although Epoxy resins are excellent in many respects, I have seen a number of joint failures on Aluminium alloys; and these were [I believe] typically down to inadequate surface preparation. ... We had great success with Araldite 2002, on glass/epoxy [presumably you remember Ciba Geigy 'F-Board'], but results on Aluminium alloys were much less predictable. Where the joint design permitted; we preferred to use Loctite 638, and found this to be 100% reliable [even with very rudimentary surface preparation] ... and this was why I recommended it to Chris. Now: Your experience is much more sophisticated than mine, so the question is: How do you prepare the Aluminium alloy surface, to ensure good bonding? ... Chris's forks project would be an ideal example for a 'Tutorial'. Many Thanks MichaelG.
Chris Denton | 27/08/2015 13:42:37 |
275 forum posts | Finished now. Thanks.
Edited By Chris Denton on 27/08/2015 13:43:29 |
