Warco VMC belts.
Mark P.19/06/2015 14:09:04
634 forum posts
9 photos
Have any other owners found that when used in low speed (190 RPM) the rear drive belt seems too short ie the motor is tight against the stop, and the motor pulley has to be repositioned on the shaft to get the belt to line up? Am I missing something.
Mark P.
Vic19/06/2015 14:57:42
3453 forum posts
23 photos
I normally run my VMC in the A I, II & III range giving me 560, 1370 & 2100 rpm as it only requires slipping one belt. I have run mine at 190 rpm though and have never altered the pulley or motor mount so it must have been ok. I have changed one of the belts on mine though as it was pretty poorly made. I took the old one along to a local motor factors who managed to supply a fan belt the right size. I've also used Halfords in the past for drive belts! Let us know how things turn out.
Mark P.20/06/2015 16:54:23
634 forum posts
9 photos
Hi Vic, have solved the problem, bought an inverter drive kit!
Regards Mark P.
Vic20/06/2015 19:23:21
3453 forum posts
23 photos
In that case you may want to get a rev counter? I understand these can be had quite cheaply on eBay and can take a direct reading from the quill pulley for accuracy.
Mark P.20/06/2015 22:42:15
634 forum posts
9 photos
Hi Vic, yes I will have a look at them on ebay I guess it would be useful.
Mark P.
