michael burton 1 | 07/04/2015 21:41:27 |
126 forum posts 32 photos | hi managed to aquire a boiler for my project but is fitted with 2 TOP FEED clacks and not the usual side mounted will this be a major prob as i have read of this postion being used in full size boilers on the net its a marine style boiler if that helps. also roughly how do you work out pump size and injector size im guessing the injector you just turn on as required and im planning on using a modifyed hand pump as an axle pump plumbed straight up to one off the clacks mike |
JasonB | 08/04/2015 07:28:30 |
![]() 25215 forum posts 3105 photos 1 articles | Fit a tube to the boiler side of teh clack valve so it takes the water down below water level. You will need to work out the amount of steam you are likely to use and work back from there as far as pump and injector, but look at other traction engines of similar size to see what they use to make sure you ar ein the right ball park. Without knowing the cylinder size, stroke, rate of work, boiler size then its hard for anyone here to give a definate answer. |
michael burton 1 | 08/04/2015 10:28:50 |
126 forum posts 32 photos | hi jason do you mean a tube on the inside of the boiler so that it then deposits the water below water line? |
JasonB | 08/04/2015 11:11:35 |
![]() 25215 forum posts 3105 photos 1 articles | Yes, I'd fit it to the actual valve so rather than comming straight out teh valve and into the steam space it gets taken to lower down in the boiler |
duncan webster | 13/04/2015 19:25:38 |
5307 forum posts 83 photos | why? It doesn't make any difference to steam raising whether you put it in under water or just let it fall through the steamspace |
