Request for suggestions to deal with clearance problem
David Haynes | 26/03/2015 20:17:38 |
168 forum posts 26 photos | Hi Folks, I have asked this question elsewhere but am now able to also post images here to go with the query. Edited By David Haynes on 26/03/2015 20:19:20 |
JasonB | 26/03/2015 20:24:14 |
![]() 25215 forum posts 3105 photos 1 articles | Can you not take the hole upto 13/16" so more of the fixings are in teh bush? you will still have a 1/32" lip all round to locate the bush, may have to nick the inside of the flange for it to fit in. Does your drawing have the bush higher up eg ctr 1/2" diwn from the wrapper top rather than 1/2" down from the flanged backhead? Edited By JasonB on 26/03/2015 20:27:05 |
JasonB | 26/03/2015 20:57:17 |
![]() 25215 forum posts 3105 photos 1 articles | With 13g copper as per your post you won't need to notch for a 13/16" hole but if 12g like on the LBSC drawing then a slight notch which won't hurt will be needed then keeping teh bush at 7/8" OD it will stop the holes going through the side Edited By JasonB on 26/03/2015 21:00:18 |
David Haynes | 26/03/2015 22:35:23 |
168 forum posts 26 photos | Thanks Jason, I has wondered about reducing the step on the bush to only 1/32". However, as this step is only to act as a register for concentricity and give a greater solder contact area, and not resist pressure, that should not be a problem.
Dave Edited By David Haynes on 26/03/2015 22:37:02 |
julian atkins | 26/03/2015 22:49:28 |
![]() 1285 forum posts 353 photos | hi david, what you propose above is what alec farmer of Reeves fame always advocated and in his book, and what don young did in his later designs, and what i have always done. cheers, julian |
David Haynes | 27/03/2015 08:19:19 |
168 forum posts 26 photos | Thanks Julian, Jason, I have corrected the small error - it looks better now. Dave |
