Screwcutting gears
Speedy Builder5 | 02/02/2015 10:53:56 |
2878 forum posts 248 photos | Anyone tried HPCGEARS for replacement screw cutting gears for the Boxford AUD lathe. I have been searching without success for a 24 tooth gear, and see that the above company sell 18DP gears in steel for not too much money ex-stock - also it looks like they do 100 tooth and will make specials (127 ??). Could be a cheaper way than hunting for the hens tooth 100/127 metric conversion gear. Yes, you would have to bore out and put the keyway slot
John Stevenson | 02/02/2015 11:03:07 |
![]() 5068 forum posts 3 photos | Only problem is HPC's gears are the modern 20 degree pressure angle standard and Boxford / Myford etc are all the older 14.5 degree standard.
Also never put the words specials and cheap in the same paragraph when talking with HPC gears. Whilst the stock gears are reasonable there specials are based on someone in industry being broke down where speed and availability are forefront in respect of price.
For the metric translation gears they often come up on ebay under Southbend as opposed to Boxford. |
Saxalby | 02/02/2015 11:25:13 |
![]() 187 forum posts 33 photos | Also, have you tried G&M tools. They usually have lots of Boxford change wheels. Barry Or Bede Tools http://www.bedetools.com/page31.html Edited By Saxalby on 02/02/2015 11:35:01 |
MalcB | 02/02/2015 16:01:48 |
257 forum posts 35 photos | RDG tools have an odd few gears but Tony at www.lathes.co.uk carries biggest stock of Boxford gears. |
Speedy Builder5 | 02/02/2015 19:21:42 |
2878 forum posts 248 photos | Thanks for your advices - still a 24Tooth gear seems to be an enigma.
Robbo | 02/02/2015 21:32:19 |
1504 forum posts 142 photos | Don't forget John Ward at Latheparts.co.uk for Boxford parts and changewheels. Although notoriously difficult to track down, its still Winter so he should be in the workshop and not roaming the Scottish hills. |
Mark C | 02/02/2015 23:45:36 |
707 forum posts 1 photos | Bob, have you asked on the yahoo boxford site? **LINK** Mark |
thaiguzzi | 08/02/2015 06:03:48 |
![]() 704 forum posts 131 photos | Posted by Robbo on 02/02/2015 21:32:19:
Don't forget John Ward at Latheparts.co.uk for Boxford parts and changewheels. Although notoriously difficult to track down, its still Winter so he should be in the workshop and not roaming the Scottish hills. Cheapest parts by far for Boxford lathes. +1. |
Speedy Builder5 | 08/02/2015 07:53:24 |
2878 forum posts 248 photos | Thanks for all your help, seems like John Ward has come up trumps. |
