Ricardo | 29/11/2014 15:10:35 |
18 forum posts 4 photos | Hi I am about to start construction of LBSC Doris. Would be grateful to know if anyone has a list of dimensional errors on the drawings. Thanks Richard
Weary | 30/11/2014 16:32:53 |
421 forum posts 1 photos | Suggest that you try looking on this site: (You may have to join to use the site, but it is free, etc.) Some of the members have this locomotive, and at least one, username runner42 is currently building. I know that he has found an error in the regulator block. There is also an interesting series of posts on bringing the boiler up to date - with particular reference to meeting the current 'Aussie boiler regs'. (The site is run and administered by an Australian, and has a strong representation from that area.) Regards, Phil |
stan pearson 1 | 30/11/2014 22:29:03 |
![]() 135 forum posts 2 photos | Hi Richard I have built and still have a 31/2" Doris, I don't remember any real issues with the drawings but I have always used drawings as a guide only and check things before I cut. I don't remember problems with the regulator but it was a long while ago when I made it. Stan |
J Hancock | 06/12/2014 18:08:22 |
869 forum posts | I'm not sure if the law about burning witches ( heresy ) has been withdrawn so criticism of errors, or design flaws , has to be avoided. However, I would suggest you carefully go through the dimensions of the drawing relating to clashing of the rotating parts with stationary objects over the full movement ( up and down ) of the axleboxe and complete 360deg rotation of parts.. Connecting rods fouling slide bars or the bottom end of the expansion link . Coupling rods hitting weighshafts , or crossheads ! Valve spindles not lining up with centre of expansion link , also eccentric rod connections well out of line with ' reality '. On the drawing these will all ' look good', only a careful check placing the drawing dimensions onto squared paper will reveal the 'truth'. Reading the write up of the day , end to end ,is useful and will include some errors , but not all ! Even if you find no errors , the time will have been well spent. |
