chipmaster motor
garrygun20/11/2014 22:18:28
70 forum posts
Hi guys,need to replace the motor variator, what size motor hp would be a good replacement in 3 phase?
i will probably fit a speed controller at a later date.
Thanks Garry.
garrygun19/12/2014 12:48:21
70 forum posts
Posted by garrygun on 20/11/2014 22:18:28:
Thanks Garry.
Any ideas please.
Ian Parkin19/12/2014 15:03:41
1174 forum posts
303 photos
Same size as was fitted ?
3 hp 2.2kw should be fine for a chipmaster
garrygun19/12/2014 20:09:09
70 forum posts
thanks for your reply, there is no info on the motor so couldnt tell what HP.
Thank you.
Ian S C20/12/2014 10:26:52
7468 forum posts
230 photos
The Chipmaster we had at school 1962/63 had a 5hp motor, the rest of the workshop was run off line shafts driven by a 10hp motor, lathes mills, shapers, etc, etc.
I'd say a 2hp to 3 hp motor with electronic speed control.
Ian S C
Alan Jackson20/12/2014 10:57:53
276 forum posts
149 photos
I have got a 1.5hp 3 phase motor running with an inverter. The variator has been removed, it was ok but takes up too much power. This motor serves me well, it is probably a bit down on power for larger diameters where I sometime have to use the backgear. I would suggest a minimum of 2 hp but this will depend on what you use the lathe for.
Alan
Keith Long20/12/2014 11:01:39
883 forum posts
11 photos
There is quite a lot of info on the lathes.co.uk website about the Chipmaster and the various permutations of motor and variator that were fitted over the years. You might also get more advice from the Colchester Yahoo group, but there isn't a great deal of traffic on there now after all the messing about Yahoo did.
Keith
Edited By Keith Long on 20/12/2014 11:02:16
