3 1/2 Britannia
Wheel bearings
peter smith 513/11/2014 21:57:34
93 forum posts
I am attempting to machine a set of wheels for 3 1/2"g Brit and the friend wants to have ball races. The drawing bits in my possession show very little. Any one made one? Have you got the spec for the bearings. Reeves used to supply sets but only have those for the drivers and I have the last ones from the previous owners stock.. Many thanks in advance
julian atkins14/11/2014 00:49:03
1285 forum posts
353 photos
hi peter,
i would tell your friend that on a 3.5"g loco it's a complete waste of time and needless complication to fit ball races to the axleboxes/axles. there are far more important bits to worry about on LBSC's Brit than the axlebox bearings. ive only ever fitted plain bearings on all my 3.5"g and 5"g locos, though i do have a firm adherence to split axleboxes for same.
cheers,
julian
Derek Drover16/11/2014 13:19:29
90 forum posts
I'd disagree... My father built his Brit back in the 70's and fitted sealed roller bearings in it.. I don't know where he got them from (I doubt he'd remember now either), but this engine still goes strong and there's little chance of the axles/bearings wearing out. It can be a fiddle finding some of the right size, but it could save a lot of work in the future.
Have you looked at "Simply Bearings" website?
ta
del.
peter smith 516/11/2014 16:12:58
93 forum posts
It's the sizes of the bearings that I need.
Pete
GWRdriver16/12/2014 03:53:06
19 forum posts
I can't address your question specifically as it relates to Britannia, but I've tried to use ball bearings in a couple of locos, always with no success. I'm sure they would be a great running success, . . IF I could fit them in. Invariably a small ball bearing with an OD which will fit within the limits of a typical axle box, has an ID such that it reduces the axle diameter axle to the point where it can become a weak point and undersized for the wheel. Personally I like to retain as much axle diameter to the back of the wheel as possible.
A solution is to use needle roller bearings and matching hardened inner races. Needle bearings require careful fitting but they can work out quite well as long as their fitting, alignment, and lubrication needs are looked after.
Cheers,
Harry
Edited By GWRdriver on 16/12/2014 03:53:52
peter smith 516/12/2014 09:10:05
93 forum posts
Hi
Many thanks for those who read and replied. Wheels and axles turned to the sizes on the drawing and posted off. Most probably the loco will never ( like many others ) get above room temperature and breath fire and steam.
Merry Christmas
Pete
