Here is a list of all the postings GWRdriver has made in our forums. Click on a thread name to jump to the thread.
Thread: Build a GWR Pannier tank loco. |
06/07/2017 23:35:53 |
If this is the LBSC "Pansy" you can count on their being a few errors, although how many and how serious they are I don't know, but all have probably been sussed out and posted or printed somewhere. |
Thread: Which steam oil |
18/02/2016 00:10:30 |
>>(I) have a couple of questions: compound steam oil - 460, 680 or 1000? I've been suggested 1000, but I think it should be 460?<< I think you are correct. I've been using 460 (or thereabouts) steam cylinder oil for 40+ years on all scales with excellent results. The advice to use 1000 is overkill IMHO and is a symptom of the "More/bigger is better" disease which seems to be creeping in everywhere. There is propaganda being spread that all of today's so-called "steam oil" is only a gear oil in disguise, and some of those oils may very well serve well, but an engineer from a well-known petroleum brand assures me that a proper steam oil is still being made. I contacted that company some years ago to suss out a rumor that steam oil was soon to be discontinued. His answer, in brief, was no, the world was still full of steam powered industrial machinery all of which needed good old steam oil. Edited By GWRdriver on 18/02/2016 00:12:59 |
Thread: Tich Small Boiler Joint question |
18/12/2015 14:25:41 |
Hello Dave, I prefer the interior butt & strap joint, for the reasons mentioned, . . . with qualifications. The only riveting absolutely necessary is what is required to hold the joint in place and keep it snug during soldering. Otherwise there's essentially no structural benefit from the rivets - it's all in the solder. For that reason it's important to get complete solder penetration to this joint and to do this, in addition to keeping the surfaces scrupulously clean, I file a slight relief angle (creating a "V" ) on the abutting edges of the barrel. This V helps admit and distribute solder along the joint. I also file a solder port (wide spot) every inch or so along the joint, likewise to provide entry points for the solder. I also grind (by Dremel, etc) shallow solder paths in the solder side of the strap to help solder wick to the edges of the strap. Tiny details I admit, but this will help insure a sound joint. Edited By GWRdriver on 18/12/2015 14:26:18 |
Thread: Belpaire boilers |
05/09/2015 03:01:51 |
Hello Martin, My general approach, when starting from scratch, is to assume the top edge of the flue nest is located at or just under the center line of the barrel. This isn't an absolute, but rather a starting point. This will put the upper surface of the firebox crown sheet a short distance above the barrel centerline, equal to whatever allowance you want to make for the radius of the formed head, plus two layers of copper. Does this help? Harry |
Thread: 3 1/2 Britannia |
16/12/2014 03:53:06 |
I can't address your question specifically as it relates to Britannia, but I've tried to use ball bearings in a couple of locos, always with no success. I'm sure they would be a great running success, . . IF I could fit them in. Invariably a small ball bearing with an OD which will fit within the limits of a typical axle box, has an ID such that it reduces the axle diameter axle to the point where it can become a weak point and undersized for the wheel. Personally I like to retain as much axle diameter to the back of the wheel as possible. A solution is to use needle roller bearings and matching hardened inner races. Needle bearings require careful fitting but they can work out quite well as long as their fitting, alignment, and lubrication needs are looked after. Cheers, Harry Edited By GWRdriver on 16/12/2014 03:53:52 |
Thread: Lubricant grades for cylinder/ bearings ect |
29/06/2014 02:11:36 |
Hello Mark, I have found that a good quality steam cylinder oil of around 460 weight is satisfactory for everything from Ga1 to 7"+ga with moderate superheat (ie, steam drying.) For general track and workshop lubrication I have found that common hydraulic oil (ISO-68) is perfectly satisfactory for everything from motion work to spindle bearings. |
Thread: machinery covers |
12/02/2014 20:58:53 |
It's difficult to say how effective it will be, each situation is different, but living in the high humidity of the southern US I have found that along with the usual care, and a little preservative oil now and again, a small circulating fan has done wonders to prevent any condensation (and subsequent rusting.) Edited By GWRdriver on 12/02/2014 21:00:06 |
Thread: Peter Rich Newport South Wales RIP |
12/02/2014 18:02:20 |
A couple of years ago I posted a few questions on locomotive details, basically "How'd you do it?", to one of the model engineering boards I haunt and I was answered off-board by "Taff", a name which aside from that particular ME board I had not run across despite years (actually decades) of reading ME and not so many EIM. (Perhaps I should re-read some of these volumes and pay closer attention to the bylines.) Anyway a brief, friendly, and very helpful personal correspondence followed which eventually included several photos of his beautifully done GWR locomotive models. I too am sorry to hear of his passing. |
Thread: Clarkson Stirling Single 3.5" |
21/04/2013 22:55:00 |
Posted by Bruce Voelkerding on 21/04/2013 15:03:30:
I have just had contact with Blackgates and they have acquired the drawings and patterns for the Clarkson's designs. They now have the Stirling 8' Single 4-2-2 drawings, with castings to come. Now would be this be for the 3.5"ga version or the 5"ga? |
Thread: 5" Baker Valve Gear |
05/01/2013 00:50:05 |
Posted by fizzy on 26/12/2012 00:30:15:
the dockstater (spelling??) program works just fine
Dockstader does work just fine but for future reference all the Dockstader programs are primarily proofing programs rather than design programs. Certainly it can be a design tool, but you must first design your valve gear, or develop approximations to your design, and the results can then be plugged into Dockstader, the behavior of the gear analyzed, and then make and view the results of adjustments made to optimize the operation. |
Thread: Bridget Drawings |
04/01/2013 16:26:24 |
His last known address (2008) is Lidesdale 5 Dipwood Way Rowlands Gill Tyne & Wear NE391DH |
04/01/2013 13:35:49 |
It was a bit odd from the beginning. One can build the complete chassis from the articles in ME (May 1970 - March 1972) but there the series unceremoniously ended without explanation. Rumour had it that there was a disagreement over publication rights. There may still be a disagreement over publication rights and Ken has elected to be the sole source for drawings. I have virtually all the drawings beyond what were published in ME and these were acquired driectly from Ken in Rowlnads Gill. At that time I believe he was still offering castings direct. That was in 1999 and I don't know if Ken is still living. Edited By GWRdriver on 04/01/2013 13:40:36 |
Thread: Jessie and Bridget boiler |
16/12/2012 15:16:26 |
Hello Ian, If I understand correctly you propose to build a Bridget. I can't provide a definitve answer to your question but I do know the Bridget boiler fairly well and it would be reasonable to assume that Ken Swan adapted at least the details if not the entire Bridget boiler to Jessie. From measuring two small elevation drawings the OA length and other major dimensions appear to be the same but that could very well be misleading. I would be glad to quote and compare OA dimesions with you if you wish. |
Thread: 2 1/2 Inch Gauge King Arthur Class "Elaine" |
11/07/2011 13:25:42 |
Hello Steve,
I haven't spoken with my friend in a while . . . his Elaine
project is in backgear, but I'll post him soon and ask his
impressions. I have a chum in Devon who hangs out with the 2.5"ga
gang and the calibre of work and depth of resources the Society does
and creates for itself is impressive. Best, Harry |
10/07/2011 21:06:04 |
Steve,
This can be a very attractive loco. I don't build in 2.5"ga
but I have several friends who do, and one of them threatens a start on
the Elaine soon. I suppose my comment would be a little off-topic
as it has to do with the boiler. I will build the boiler for this
loco and will use a materials kit supplied by Reeves andfurnished to me by the owner
. I have used many plate sets from the old Reeves in the past and
all have been completely satisfactory, but the plates in this recent
set are very poorly done, particularly the throat sheet which is
unusable as supplied and will need to be completely reformed. If
you buy your boiler out this won't be of concern, but should you use a
Reeves boiler set I hope you fare better. It appears to me the
plates were made by someone with no understanding of what they are or
how they are to be used as they appear not to have been fully closed
about the forms. |
Thread: Goodwin Castings |
12/10/2010 20:44:31 |
Posted by Paul White 3 on 12/10/2010 17:53:25:
Stirling Single, GWRdriver, Sorry to be the bearer of bad news. Paul,
Not at all . . . it saves me spending time chasing down the Conway drawings. Thanks, GWRdriver |
12/10/2010 04:06:33 |
Stirling,
I'd forgotten about this thread . . . So the Conway cylinders
might be a fit? I'll have to take a look at the drawings for
Conway to see how close they are but I have all but resigned myself to
brazing up the cylinder assemblies of bronze stock. Cheers, GWRdriver |
17/08/2010 02:15:13 |
Stirling,
I also acquired a set of Goodwin castings not too long ago, the 3.5"ga Sirling, with drawings by The Locomotive Company
. My castings are missing the cylinders which I understand Dave
failed to complete before retiring. What have you found? GWRdriver |
Thread: Jessie 040 7.25 gauge |
01/04/2010 04:16:30 |
I bought my drawings directly from Ken around 1999 so he has been
selling them direct for at least that long. It would not surprise
me to learn the disagreement over pricing was the percentage of the
Reeves price which made its way back to Ken. |
