How to use Wigglers ?
ElectroFrank02/10/2014 21:18:38
1 forum posts
I am a beginner with the lathe, I just have a Unimat Classic with a few accessories.
I have bought a set of wigglers, but I have no idea how to use them ! Not an intuitive device !
Please can anyone give me a link to a good page on "How to use Wigglers" ?
Brian Wood03/10/2014 18:30:21
2742 forum posts
39 photos
Hello ElectroFrank,
Welcome to the Forum
Wigglers are really intended for use in centreing work under a vertical milling machine spindle. At this stage in your workshop experience I would leave them in their packaging, they are of little use on a lathe. Later on when you have added a mill would be the time
I suggest some reading on lathe work to develop your understanding of the subject. A good start would be with Workshop Practice #34 by Harold Hall, Lathework, a Complete Course from Tee Publishing and well worth the £7.95 it is priced at
Bob Loader has also written WPS #32 based on the Unimat 3 lathe that you might find helpful, same price and supplier as above.
Regards Brian
Jack Foreman 103/10/2014 19:51:28
99 forum posts
17 photos
I can recommend Harold Hall's book too. An excellent introduction to lathe work. I'm working my way through mine at the moment. Welcome to the Forum
JohnF04/10/2014 17:47:09
1243 forum posts
202 photos
Hi Frank, you can use a wiggled on a lathe, indeed there is one job I do where it would be impossible without a wiggler. Below is a link to a page with some info, I don't have a photo handy of the particular piece I make but if you PM me I'll see what I can do.
http://www.toolsandmods.com/lathe/mini-lathe-center-finder
Edited By JohnF on 04/10/2014 17:48:03
Nobby04/10/2014 19:36:04
587 forum posts
113 photos
Hi Frank
I photo may help new members a Wobbler/ edge finder may be confused with a wiggler as in John's post.
They are both useful in the home workshop and at work
Nobby
AndyB04/10/2014 21:27:11
167 forum posts
7 photos
Hi Frank,
I would agree with the book choices but wobblers are not only for mills. I use one for centring jobs in the four jaw chuck.
Mark your centre with a fine pop, mount the body of the wobbler in the tailstock chuck and set the point in the centre pop. Rotate the chuck by hand and set the job in the chuck for no run out, use a test indicator to check your run out if it is critical, otherwise your eye is pretty accurate - you are looking for no sideways movement of the wobbler - er, no wobble - to set the job on centre.
If you have one of the sets that are common now, the different ends are for different size centres and for finding the edge of a job - same principal as for centring, but you use the barrel-ended wobbler. Set the machine (lathe or mill) going and watch for the wobbler to straighten as you bring the job up to it, When it is straight then the machine head is dead in line with the edge (assuming that you have a good set and the barrel is concentric with the shaft. You then zero your dials and work coordinates from that datum.
As Nobby points out (I think), a wobbler is east of the pond, a wiggler is west of it.
Andy (I will duck down below the parapet now)
AndyB06/10/2014 21:08:14
167 forum posts
7 photos
Oops!
Sorry, I have just reread my post. embarrassed
The head would NOT be over the edge of the job, it would be half the thickness of the barrel away from it...which is why they stipulate the width of it on the packaging. wink
Sorry again. sad
Andy
