John Haine | 09/10/2020 17:22:17 |
5563 forum posts 322 photos | "Misleading the public is always an option. " Verging on the political, Dave!
As a matter of interest, what software do you use for that analysis? I'm using R Studio, which is free and wonderful but tricky to drive. I used to use Excel but ran out of rows.... (Oops, I'm getting political now!) |
SillyOldDuffer | 09/10/2020 18:50:34 |
10668 forum posts 2415 photos | Posted by John Haine on 09/10/2020 17:22:17:
As a matter of interest, what software do you use for that analysis? I'm using R Studio, which is free and wonderful but tricky to drive. I used to use Excel but ran out of rows.... (Oops, I'm getting political now!) Very embarrassing to run out of rows whilst using Excel! I'm using python3 with numpy to do the analysis and matplotlib to draw the graphs. All available free for Windows, Mac & Linux. The program is: (Source can be emailed if it's useful.) Most of the complexity is drawing the graphs, hiding axes and so on. The number crunching is more straightforward with numpy, for example
Line 1 allocates meaningful names to the array columns Line 2 loads a 2D-array called data from the filename, which is a text file. Line contains data as per line 1, each value separated by a space. By default double precision floats are used, many other options. All my calculations are done with this one array, but I could have several. Line 3 does the heavy lifting. The array is addressed [row:column] so data[ : period] means 'all the rows in the period column'. np.average() does what it says on the tin, in this case averaging the column. The other unusual syntax is python3 format strings, for example: f"Average {average:.1f}" It creates a formatted string from whatever is between the quote marks. {average:.1f} means "insert the value of the variable average and display it as floating point to one decimal place." Dave
Edited By SillyOldDuffer on 09/10/2020 18:52:16 |
Joseph Noci 1 | 10/10/2020 06:44:17 |
1323 forum posts 1431 photos | Dave, Perhaps you have seen this already - if not, it may be of interest? Joe |
SillyOldDuffer | 10/10/2020 11:04:57 |
10668 forum posts 2415 photos | Posted by Joseph Noci 1 on 10/10/2020 06:44:17:
Dave, Perhaps you have seen this already - if not, it may be of interest? Joe Thanks Joe, I hadn't seen Bertrand's work. It is interesting, though not directly - I'm exploring a springy carbon fibre whereas he used wood and a hard drive bearing. Re-purposing a hard-drive hadn't occurred to me, but they're a super source of high-tech mechanics. Have to admit I'm awash with new information and having trouble taking it all in. Three books, plus a couple of John Haine papers on the relationship between Q and pendulum frequency stability. To say the maths is a challenge is an understatement! Keep it coming though, all contributions are grist to the mill, Ta Dave
SillyOldDuffer | 10/10/2020 11:15:56 |
10668 forum posts 2415 photos | Today's graphs are more of the same - the pendulum is swinging ever more wildly. Whether that's the sole cause of the average period shifting is unknown. It's not right. Rather than stop the experiment, I'm going to move the magnet about 1mm further away - my lash-up makes this easy. Then see what effect that has on the period. I predict it will settle, less wild, but anything could happen... Dave |
SillyOldDuffer | 10/10/2020 11:26:35 |
10668 forum posts 2415 photos | Disaster! Moving the electromagnet fouled the IR wires enough to pop the sender LED out of it's socket. Reseating the LED, my sleeve caught the clamp stand and moved the electromagnet about 10mm so I had to guess where it came from. As the adjustment isn't from a known base the experiment has to be repeated. Maybe I should take up knitting. Dave |
Peter Bell | 10/10/2020 12:55:34 |
399 forum posts 167 photos | At least you didnt knock it over Dave, thats my normal trick! Dont want to detract you but perhaps someone can help? I would like to do some analysis on my simple clock (posted 9/9/20 doesnt time fly!) but your setup is way beyond me, is there any easy software I could use to plot my 1/2 sec pulses to give something like period variations? Thanks Peter |
SillyOldDuffer | 10/10/2020 14:14:37 |
10668 forum posts 2415 photos | Posted by Peter Bell on 10/10/2020 12:55:34:. ...is there any easy software I could use to plot my 1/2 sec pulses to give something like period variations? Thanks Peter What operating system do you have Peter? If period is already being calculated by your Arduino, no problem Serial.println()ing it. Unfortunately the Arduino IDE's serial monitor doesn't allow data to be saved to a file, but many other terminal emulators can do the needful. I use GtkTerm on Ubuntu, Hyperterm was free on Windows but you have to buy it now. YAT should do the job - I've not tried it. Others available. Once the data is in a file, almost any spreadsheet should be able to import the numbers and draw the period variation graph. LibreOffice is free. Have a go, shout if you get stuck. Dave
John Haine | 10/10/2020 15:17:53 |
5563 forum posts 322 photos | You can select all / copy the contents of the Arduino serial monitor window. Place your cursor in the window and click; then do a very rapid ctrl+A / ctrl+C - then you'll see the text briefly highlighted - then switch to a text window and paste the data into it. If you just do a print of anything each time a swing is detected the monitor timestamp will provide the time. The only problem is that the each record is a text string, and you have to parse the string to extract the actual numbers. I can provide some Excel for that. For Windows there is an excellent serial terminal program called Termite which is particularly easy to use.
John Haine | 10/10/2020 17:36:39 |
5563 forum posts 322 photos | Update to that - it's much easier if you turn off autoscroll on the window, you can select/copy at leisure. |
Peter Bell | 10/10/2020 17:40:30 |
399 forum posts 167 photos | Many thanks for the replies. Before I can do anythingI need to do is move my clock from the workshop near to where the pc lives, easier said than done, working on it but other things are to do first! What I was hoping was extract the timings from the bdc sensor negative going pulse in the blue trace and see the speeding up and slowing down of the pendulum as the actuating coil switches. I've got a Microset and sensors, nice bit of kit but never had much success with it. Peter |
John Haine | 10/10/2020 21:07:13 |
5563 forum posts 322 photos | Another approach is to log the time on a Pi next to the clock, and VNC into the Pi over WiFi from the PC to extract the data. When you say "speeding up and slowing down", do you mean the increase in amplitude? It may be hard to resolve the negative going pulse amplitude well enough to see the amplitude change with a Microset which has a resolution of 10 us I think (i.e. 100 kHz clock). I measure the opto pulse length using a "picPET" witha 10 MHz clock and you can easily see the amplitude and phase change when the clock is impulsed. You may have better luck using the "offset sensor" method of amplitude measurement with the Microset (described on Mumford's website I think). |
Michael Gilligan | 10/10/2020 23:44:16 |
![]() 23121 forum posts 1360 photos | I have just found a fascinating paper about Galileo’s pendulum experinents: **LINK** http://www.pitt.edu/~pap7/A%20Phenomenology%20of%20Galileos%20Experiments%20with%20Pendulums%20with%20Supporting%20Document.pdf Fig. 7 and the discussion about latent modes might be relevant to the behaviour of Dave’s flexing carbon rod. MichaelG. |
Michael Gilligan | 11/10/2020 00:24:28 |
![]() 23121 forum posts 1360 photos | Also found this little gem : **LINK** http://articles.adsabs.harvard.edu/cgi-bin/nph-iarticle_query?1957SvA.....1..637F&classic=YES Button at bottom left should download all eleven pages as a PDF MichaelG. |
SillyOldDuffer | 11/10/2020 11:07:43 |
10668 forum posts 2415 photos | Posted by Peter Bell on 10/10/2020 17:40:30:
... What I was hoping was extract the timings from the bdc sensor negative going pulse in the blue trace and see the speeding up and slowing down of the pendulum as the actuating coil switches. I've got a Microset and sensors, nice bit of kit but never had much success with it. Peter Should be possible, the manual says 'Both versions of MicroSet can be plugged into a personal computer to capture beat times for later analysis and study. This allows you to see how a clock’s rate varies over time, and to evaluate trends in these fluctuations that can help you diagnose problems and understand erratic behavior. You can also use the computer to create graphs of rate changes, or collect many periods and calculate an average rate over hours or days.' Sadly the manual is coy about exactly what data format is sent to the computer and the detail of their optional software's features. (Traditional measuring functions are explained, which is probably enough for most users.) Probably easier to modify the software on your clock's Arduino to output periods to the USB, and then use Termite and Excel (or similar) to analyse it. Dave
SillyOldDuffer | 12/10/2020 14:12:56 |
10668 forum posts 2415 photos | Today's graphs show the improvement made by moving the electromagnet further away from the bob. The bob isn't swinging ever more wildly and Standard Deviation has dropped from 637 to 39.4, much better. Might be some correlation between period and barometric pressure too, though 0.34 is far from convincing. Not known what caused the odd bump at about tick 95750 (approx 12:45am) where the period suddenly increases. It doesn't correspond to temperature, pressure or humidity. Possibly a heavy lorry passing outside or a gust of wind got past the loose fitting garage door. Zooming in doesn't help: Bugs detected: 450 records of 200,000 were deleted manually from the log because the relative humidity sensor occasionally returns NaN (not a number), which upsets loading data from the log file. Improvements: better for the log file to record real time as well as tick times. Next steps. Test code changes to log real time and fix humidity sensor misreads. Add code to measure Q. Upgrade the mechanics so the shield can be fitted, and an amplitude detector so impulses can be reduced further. Dave
Michael Gilligan | 12/10/2020 16:18:35 |
. Have you read that Galileo reference that I linked, Dave ? MichaelG. Edited By Michael Gilligan on 12/10/2020 16:33:53 |
SillyOldDuffer | 13/10/2020 10:58:50 |
10668 forum posts 2415 photos | Posted by Michael Gilligan on 12/10/2020 16:18:35:
I have, and very interesting it is too. I don't recall seeing a description of how Galileo got results before, and recreating the conditions was revealing. Galileo was clever! Whether I understood it is another question. Far more to pendulums than I remember from School Physics. Reading Fedchenko too, another cracker. Trouble is I have to read anything remotely difficult at least twice and take notes. Takes ages. Dave
Michael Gilligan | 13/10/2020 11:52:16 |
![]() 23121 forum posts 1360 photos | Posted by SillyOldDuffer on 13/10/2020 10:58:50: […] Far more to pendulums than I remember from School Physics. […] . Not trying to nudge you into little-charted territory, Dave .. [ O.K. perhaps I am ] but I do think the discussion about latent modes might be directly relevant to the behaviour you are seeing. MichaelG. |
duncan webster | 13/10/2020 13:29:59 |
5307 forum posts 83 photos | Way back in the mists of time JARadford (I think) had an article in ME about an electrically impulsed clock where instead of impulsing the bob he moved the top pivot from side to side, when the bob got to extreme left, the pivot flicked to the right and vice versa. I can see how this would work, but I wonder what effect it had on time keeping. Unfortunately I can't find the article |
