Martin Kyte | 11/02/2020 08:49:16 |
![]() 3445 forum posts 62 photos | Posted by Martin Kyte on 11/02/2020 08:48:18:
Posted by Michael Gilligan on 10/02/2020 17:11:15:
Posted by Martin Kyte on 10/02/2020 13:02:19:
So now we have established that the bar is not going to be any any stiffer and building a rod within a tube can only make it less so. […] .
My reading of Graham Meek’s simple practical test results indicates quite the contrary !! [quote] In the Torque test the plain bar took 1.13 kg to deflect the arm 0.05 mm, while the boring bar under a pre-tension took 1.59 kg. This time there was a much bigger improvement of 30%. [/quote] MichaelG. . P.S. I can claim no expertise in stress analysis ... but I did work for eleven years in an Environmental Test House, and have done some serious vibration testing.
Edited By Michael Gilligan on 10/02/2020 17:15:32
To be fair, Graham posted that whilst I was writing my bit so I had not read it. My point was that using the same materials, a rod within a rod not under tension,(but not loose) cannot be intrinsically stiffer. So either the bar unter tension cannot be modelled by simple linear spring theory or it's a harmonic phenomena or both. It does undoubtably practically work, as Graham has shown. I look forwards to someone moving this forward, it is quite interesting. regards Martin
Graham Meek | 11/02/2020 10:37:14 |
714 forum posts 414 photos | Just to clear things up, the Plain Bar was just that, ie not hollow, and both tests were using the same material. As regards doing further work on Boring bars I can see little in the way of improvement. I am trying a larger push rod on the bars I am currently making for a new larger design of boring head. In time I may be able to do a back to back comparison on these to see if this makes it worse or not. It might just make it better? Regards Gray, |
Michael Gilligan | 11/02/2020 10:41:53 |
![]() 23121 forum posts 1360 photos | Posted by Martin Kyte on 11/02/2020 08:49:16: To be fair, Graham posted that whilst I was writing my bit so I had not read it. . Then I gladly retract my “query” Martin ... We’re all in synch now [and yes, the whole point of it is that the bar is pre-stressed by tightening the screw] MichaelG. |
DrDave | 11/02/2020 19:45:59 |
264 forum posts 52 photos | I had a look round the office for a few fine white elephants and found these lurking in a corner: This purports to be a 10 mm tube with a 6 mm hole with a 5.8 mm pin down the centre, both 70 mm long. Material is "steel". A nominal 200 N shear load is applied at the RH end and the LH end is built in. I also found a solid 10 mm bar lurking in another corner. Varying the frequency of the 200 N load from 0 Hz to 5 kHz gave the three curves below. They are not all quite what I expected... The solid bar gave the silver curve: a typical single degree of freedom forced response curve. Good. The "Loose" curve is for the model shown above: only the outer tube has responded to the load. The static deflection is slightly greater, because it is hollow. To my surprise, the natural frequency and the size of the peak have increased (not that the axis has a log scale). The frequency has gone up because the mass has decreased more than the tube's moment of inertia, one of the useful properties of a tube. I am not sure why the magnitude of the peak has gone up. I then tied the two free ends together. I have called this "preloaded", to signify that it is modelling a boring bar when it has been pre-loaded. This has produced some interesting results. It has two resonance peaks: one for the tube and one for the bar. I am surprised that the first peak, and its magnitude, are nearly identical to those for the solid bar. Make from that what you will, because I certainly don't know! Evidently the two-piece boring bar does work to reduce/eliminate chatter, but the mechanism but which it does this is still obscure. I would suggest friction between the two parts acting to damp the vibration, but the elephants had all left the office by then & were nowhere to be found... Dave |
Michael Gilligan | 11/02/2020 20:58:03 |
![]() 23121 forum posts 1360 photos | That’s real progress, Dave If you can get the elephants back on the job ... May I suggest that [to model the contentious aspect of this] you need to apply a compressive end-load to the pin, rather than just tying both ends to the tube. My ‘arm-waving’ analysis of it is that loading the pin in compression [which is what we do by using it as a clamp] stretches the tube, and it’s that preload by extension which increases the overall stiffness. Keep up the good work, and keep the elephants fed & watered. MichaelG. |
Grindstone Cowboy | 11/02/2020 21:39:34 |
1160 forum posts 73 photos | Been following this thread with interest, and have possibly understood about 5% of the hard sums, but a thought occurred to me - it's all been about trying to stretch the the outer tube with an inner push-rod, yes? How about the other way around? Using a threaded inner, fixed at one end and with a nut and washer on the other, thus compressing the outer? No idea whether it would be better or worse, just musing.
duncan webster | 11/02/2020 22:28:14 |
5307 forum posts 83 photos | Dr Dave seems to be on the case, but if need be I have another FE man who is prepared to have a look. Would need more dimensions, outside diameter, hole diameter, rod diameter, length to name but a few. The clearance twixt rod and hole probably matters quite a lot, if it's a very good fit it will be forced to follow the shape of the outer, if not, not if you see what I mean Edited By duncan webster on 11/02/2020 22:30:29 |
Martin Kyte | 12/02/2020 09:49:34 |
![]() 3445 forum posts 62 photos | Posted by DrDave on 11/02/2020 19:45:59:
This purports to be a 10 mm tube with a 6 mm hole with a 5.8 mm pin down the centre, both 70 mm long. Material is "steel". A nominal 200 N shear load is applied at the RH end and the LH end is built in. I also found a solid 10 mm bar lurking in another corner. Varying the frequency of the 200 N load from 0 Hz to 5 kHz gave the three curves below. They are not all quite what I expected... The solid bar gave the silver curve: a typical single degree of freedom forced response curve. Good. The "Loose" curve is for the model shown above: only the outer tube has responded to the load. The static deflection is slightly greater, because it is hollow. To my surprise, the natural frequency and the size of the peak have increased (not that the axis has a log scale). The frequency has gone up because the mass has decreased more than the tube's moment of inertia, one of the useful properties of a tube. I am not sure why the magnitude of the peak has gone up. I then tied the two free ends together. I have called this "preloaded", to signify that it is modelling a boring bar when it has been pre-loaded. This has produced some interesting results. It has two resonance peaks: one for the tube and one for the bar. I am surprised that the first peak, and its magnitude, are nearly identical to those for the solid bar. Make from that what you will, because I certainly don't know! Evidently the two-piece boring bar does work to reduce/eliminate chatter, but the mechanism but which it does this is still obscure. I would suggest friction between the two parts acting to damp the vibration, but the elephants had all left the office by then & were nowhere to be found... Dave Very interesting. Effectively the rod down the middle of the bar has added another degree of freedom allowing resonant motion at two different frequencies. So maybe the best way of thinking about the tensioned bar is as two coupled oscillators something along the line of 2 pendulums of dissimilar length both hanging on a line which couples them togather. Energy will be transferred back and forth from the one to the other at at the beat frequency in a similar way to the employment of tuned mass dampers for tall buildings etc (google it). This company actually produces a tuned mass damper boring bar. I don't think for a minute that the simple tensioned bar we have been discussing approaches a tuned system however the addition of the tensioned rod certainly seems to have the effect of disrupting the single frequency simple oscillation. I did try and find a video of coupled pendulums of different lengths but so far have failed. regards Martin
Michael Gilligan | 12/02/2020 13:15:54 |
![]() 23121 forum posts 1360 photos | Posted by duncan webster on 11/02/2020 22:28:14:
Dr Dave seems to be on the case, but if need be I have another FE man who is prepared to have a look. Would need more dimensions, outside diameter, hole diameter, rod diameter, length to name but a few. The clearance twixt rod and hole probably matters quite a lot, if it's a very good fit it will be forced to follow the shape of the outer, if not, not if you see what I mean . A suggestion, if I may [and if it doesn’t involve Dr Dave’s Elephants in too much re-work] 12.0mm o/d, 6.2mm i/d, blind at one end, and tapped M8 at t'other 6.0mm push-rod, and an M8 screw to apply pressure at least 200mm long ... so that we keep the resonant frequencies down a bit preferably ‘grounded’ at the screwed end, for realism ... but O.K. to model it free-free if that’s more convenient. MichaelG.
Graham Meek | 12/02/2020 16:35:18 |
714 forum posts 414 photos | I have been looking at the clamping end of the push-rod in my boring bars. While the 45 degree flat should exhibit a straight line wear pattern of contact with the round tool bit, it does not. Instead there is a wear pattern resembling a very shallow "X". The push-rod is obviously twisting as the Allen grubscrew is tightened. This then leads on to another condition that the push-rod is experiencing. Not only is it being compressed, but there is also a twisting moment being induced. Obviously the turning effort on the end of the grubscrew is being transferred to the push-rod. Due to the wedge action at the clamping face, the twist on the push-rod can only go so far. Once the wedge action has taken place. How much more of the torque applied to the grubscrew is being absorbed by twisting the push-rod beyond this point. I had better just add that the grubscrews I use are all Half Dog points so present a flat face to the end of the push-rod. The induced twist is also of an opposite sense to the force applied by the cutting tool. Tightening the grubscrew induces a clockwise moment on the push-rod looking on the back end of the boring bar. While the cutting tool puts a counter clockwise moment on the boring bar. Thus the push-rod has now become a pre-loaded Torsion bar, similar to some suspension systems used in the past. Unlike the suspension system where the torsion bar is only dealing with the up and down movement of the suspension arm and has no compression or tension end loading. The torsion bar in the push-rod system is under compression, as well as being constrained at either end. Unfortunately the days are long gone since as an apprentice I used to push numbers around on paper working out the stresses in under carriage legs at Dowty Rotol ltd. These were the days of the slide rule, and the Olivetti computer took half a day to programme. This is a system beyond my capabilities and needs some younger grey cells. As I said in my previous post, I was sure there was a lot more going on when the boring bar is under tension using a push-rod. Obviously Arnold and George knew this too, I do not think they just stumbled across this. I have another test in the pipe line to measure this twist, but it will have to wait for some warmer weather. "There is snow on them thar hills", (just across the border in Wales), and the workshop has temporarily become a no-go area. Regards Gray, Edited By Graham Meek on 12/02/2020 16:37:24 |
DrDave | 12/02/2020 19:31:54 |
264 forum posts 52 photos | Regarding the magnitude of the pretension (or compression) on the assembly, this will have no effect on the simple, linear model that I showed above. The FE program does not even have the ability to consider preloading. Why no effect? The response is really just the sum of the vibration modes of the system: I will have to dig into a little maths, so bear with me. The natural frequency of a system boils down to frequency = sqrt(stiffness/mass). In this case, the stiffness is effectively Young’s modulus, which is independent of load (if you don’t yield it). So preload cannot affect the fine element analysis. But, in practice, there are all sorts of non-linear effects creeping in. Friction between the parts possibly being one. I see no point in following the analysis route any further, so I will bow out (and let the elephants loose again). I think physical testing is the best way forward, but I do not have access to the actuators and accelerometers requited to do this justice. Lastly, Gray’s comments and findings about torsion are interesting. However, after chatter has started, any torsional frequencies will be so high that I suspect that they play no part in the process. However, I have been wrong with some of my preconceptions on this topic and I am quite happy to be proven wrong on this, too! Dave |
Michael Gilligan | 12/02/2020 20:59:33 |
![]() 23121 forum posts 1360 photos | Posted by DrDave on 12/02/2020 19:31:54:
. Thanks, Dave ... I remain convinced that preload is the essence of this, but if the FE can’t accommodate it then I agree that we would be wasting your elephant herd’s time. Physical testing would be informative, but I don’t have access to the shakers and instrumentation either.
duncan webster | 12/02/2020 21:51:00 |
5307 forum posts 83 photos | Rather than Michael's figures it makes sense to use Graham's real figures in an FE model, then we can compare Graham's measurements with FE predictions and see where we go from there. If Graham is reading this perhaps he would supply the dimensions |
Michael Gilligan | 12/02/2020 23:01:50 |
![]() 23121 forum posts 1360 photos | Posted by duncan webster on 12/02/2020 21:51:00:
Rather than Michael's figures it makes sense to use Graham's real figures in an FE model, then we can compare Graham's measurements with FE predictions and see where we go from there. If Graham is reading this perhaps he would supply the dimensions . Fine, Duncan ... Dr Dave has already withdrawn, so it looks like your team is doing the job. The only reason I suggested a longer bar was that it would reduce the resonant frequency ... which means larger displacements for a given g, which means that a coarser mesh might provide proportionately better resolution. It’s 30+ years since I’ve done any of this ... so I may well be worrying unnecessarily. Whatever you choose to do ... I will be delighted to see some results. MichaelG. . I’m out of my depth here ... but this may be of interest : Edited By Michael Gilligan on 12/02/2020 23:09:33 |
Michael Gilligan | 13/02/2020 08:38:59 |
![]() 23121 forum posts 1360 photos | Posted by Michael Gilligan on 12/02/2020 23:01:50: . The only reason I suggested a longer bar was that it would reduce the resonant frequency ... which means larger displacements for a given g, which means that a coarser mesh might provide proportionately better resolution. . . Sorry folks ... that was rather clumsily worded, and is probably ambiguous What I mean is that any given size of elements will provide proportionately better resolution on a long bar than on a short one. Alternatively, we could express it as — a coarse mesh might suffice for analysis of large displacements. [But obviously, in any situation, a finer mesh gives better resolution] MichaelG. Edited By Michael Gilligan on 13/02/2020 08:51:26 |
Graham Meek | 13/02/2020 10:50:21 |
714 forum posts 414 photos | The overall length of the boring bar was 90 mm, 30 mm was gripped in the toolpost, in a sleeve. The push-rod was 3 mm diameter and the hole through the bar 3.2 mm. The 1/8" cutter was on the extreme corner of the bar which itself was 10 mm diameter. The push-rod is locked by an M4 Allen grubscrew. This bar also had two flats running the full length of the bar and parallel to the cutter centre-line, (see initial post). The dimension across the flats was 9 mm. These flats are used to hold and orientate the boring bar in the Boring head. This boring bar has despite an L/D of 7 when in the boring head produced: dare I say, perfect holes, in a brass fabrication to take a radial bearing. The bending loads and the torsion loads were all applied 5 mm in from the cutter end of the boring bar using a screw tensioning device and an elderly spring balance. As all the readings were taken from the same balance then it should make no odds about its age. Ideally I would have preferred a force gauge but it was a case of horses for courses. Regards Gray, |
Graham Meek | 13/02/2020 17:19:52 |
This afternoon I had a chance to make the Twist test rig I wanted to. The above drawing gives the set-up and the push-rod is the one from the Test Boring bar. The BMS block is 90 mm long by 12 mm wide and the two "C" shaped discs are 10 mm diameter and a friction fit on the push-rod. The discs have a Zero mark to coincide with one on the main block. The discs are not allowed to contact the faces thus eliminating any drag that might give a false reading. The discs are aligned with the Zero mark once all the slop has been taken out of the system, but the tool bit can just about be turned by hand. A x40 pocket microscope with a graduated graticule is used to align the Zero's. The M4 grubscrew is then tightened, which is about a third of a turn. While the disc at the tool bit end did move it was barely the width of the Zero line. This is what I would expect. The movement at the other end was more pronounced and equates to 3.436 degrees. This is approximately 3% of the tightening angle. The gap left between the disc and the test rig opened up about 0.25 mm which is in keeping with the screw thread displacement. Thus my supposition made earlier about the bar being in compression and in torsion is proven with this rig. No doubt with access to more sophisticated equipment like strain gauges it would be possible to quantify what is going on, but I am satisfied with my tests that there is a benefit to be had from this arrangement. Regards Gray, |
duncan webster | 13/02/2020 21:42:10 |
5307 forum posts 83 photos | Posted by Graham Meek on 13/02/2020 10:50:21:
The overall length of the boring bar was 90 mm, 30 mm was gripped in the toolpost, in a sleeve. The push-rod was 3 mm diameter and the hole through the bar 3.2 mm. The 1/8" cutter was on the extreme corner of the bar which itself was 10 mm diameter. The push-rod is locked by an M4 Allen grubscrew. This bar also had two flats running the full length of the bar and parallel to the cutter centre-line, (see initial post). The dimension across the flats was 9 mm. These flats are used to hold and orientate the boring bar in the Boring head. This boring bar has despite an L/D of 7 when in the boring head produced: dare I say, perfect holes, in a brass fabrication to take a radial bearing. The bending loads and the torsion loads were all applied 5 mm in from the cutter end of the boring bar using a screw tensioning device and an elderly spring balance. As all the readings were taken from the same balance then it should make no odds about its age. Ideally I would have preferred a force gauge but it was a case of horses for courses. Regards Gray, I'll produce a CAD model and send it to Gray to make sure I've got it right and then send it to my FE man. Don't expect immediate results, he's doing it out of interest, not because he's a model engineer. |
duncan webster | 14/02/2020 14:36:35 |
5307 forum posts 83 photos | Gray, have sent email with drawing |
Graham Meek | 14/02/2020 20:16:16 |
714 forum posts 414 photos | Hi Duncan, Unfortunately your email was in my Spam tray with a Google warning. Anyway I have managed to safely extract and open the dxf file. Which my version of AutoCAD did not like, it said there was an error and refused to open it. Finally using Autodesk DWG TrueView 2020 I was able to view the drawing. A couple of things wrong with the drawing, but only minor. The 3.2 diameter hole does not go all the way through, it stops 10 mm from the tool bit. The hole is then 3.05 mm from there to the tool bit, and it stops at the tool bit. It does not go all the way through the boring bar as drawn. Also the tool bit is 1/8" diameter not 3 mm. Regards Gray, |
