Lathe improvements?
Old man playing with lathes.
Niels Abildgaard30/03/2021 11:06:41
470 forum posts
177 photos
Posted by Ady1 on 30/03/2021 10:56:01:
Re: your narrow chuck work
No-one mentioned it but a recent ebay sale had the amazingly rare drummond 4jaw which was specially developed for large work bigger than the chuck itself, to fit into the gap
The jaws appear to be quite small compared to the chuck body
Edited By Ady1 on 30/03/2021 10:59:55
A new chinese precission version were just the thing for old toads.
Hopper30/03/2021 11:54:31
7881 forum posts
397 photos
Is that the standard M-Type 4jaw or something special? I have the regular 4 jaw on my Drummond and it is a nice slim body but never thought about the gap relationship.
Ady130/03/2021 12:58:38
6137 forum posts
893 photos
Michael Gilligan30/03/2021 14:13:56
23121 forum posts
1360 photos
Posted by Hopper on 30/03/2021 11:54:31:
It looks [in Ady’s posted advert] remarkably like what became the Myford special that Burnerd produced
... and the text about the reversible jaws seems to describe the style which became the de-facto standard.
I wonder what “common pattern” Drummond was using as its benchmark dont know
Niels Abildgaard06/04/2021 13:12:18
470 forum posts
177 photos
The Mega 920 versus Boxford stiffness comparison from 30 of march can maybeebe used again.
Many years ago I succeded in parting 100mm mild steel without trouble on my Boxford.
It is tempting to make a new spindle for my new 920 without any modification to headstock.
Distance from cutting point to first bearing is 110mm on the 920 and 140 on Box.
Bearing interdistance is 140 and190mm
Soft part of Box spindle is 36mm/19mm and the new 920 spindle is 40mm/28mm that is Box bends 1.26 times 920 .
length between bearings makes box 1.84 times more sensitive.
thecutting load makes spindle bending moment 1.28 higher for the Box.
For same cutting load the working point evasive movement will be 1,28 times 1.26 times 1.84 times 1.28 equals 3.8 less for the new two bearing 32908 920 spindle compared to my old boxford that was not bad.
I have just saved my self a lot of trouble.
Niels Abildgaard24/08/2021 21:02:57
470 forum posts
177 photos
My son has bougth a Quantum 310 910 lathe and I can have my beloved Weiss Mashinery 250 750 with Morsecone 4 back.That was up to now my best bid for an old geezer ideal lathe.
In the meantime I have worked on my Maximum Capacity-Minimum Volume version of Weiss 180/210 cheap as dirt lathe.
It consist of bed and sled from a 180/300 and headstock from a 210/400 and a 48mm bore spindle in some slim conical roller bearings.
The screwcutting and feeding arrangement has cost me headache but I am sure it can be handled now.Screwcutting from 0,4 to 2mm pitch comes easy and a single fine feed will do until I can make an Adjust as You cut version.
It needs to stop immiately when spindle does.
Edited By Niels Abildgaard on 24/08/2021 21:24:32
Niels Abildgaard24/08/2021 21:08:32
470 forum posts
177 photos
The gear wheels scheme is illustrated here
The fine feed via 80 teeth on spindle
First Compound 17/80
Second Compound 15/84
Leadscrew 2mm pitch and 100 teeth
Result can be calculated thus:
80multiplied by 17multiplied by 15 multiplied by 2  divided by 80 divided by 84 divided by 100 equals 0,o6mm per rev.
I would really prefer to use a 90 t gear instead of the 84 so if someone is in for a swap let us both benefit.
I have some funny gear numbers from aproximate imperial pitches on metric leadscrew and do not need them..
Let me know if You need.
For pure intelectual fun what imperial pitches between say  12 and 50 threads per inch are most important?tilspaending tal og tekst.jpg
Edited By Niels Abildgaard on 24/08/2021 21:19:36
Edited By Niels Abildgaard on 24/08/2021 21:21:22
Edited By Niels Abildgaard on 24/08/2021 21:22:07
Niels Abildgaard26/08/2021 12:54:21
470 forum posts
177 photos
Two further pictures and some thoughts (in German).
Try to click two times the pictures in the German website.
The resolution from my handheld ,8 year old Nokia phone in indoor daylight is astonishing.
German version
I am trying to get the moral fibre to part off the heavy walled pipe shown in one of the pictures.
Edited By Niels Abildgaard on 26/08/2021 12:57:13
Ady126/08/2021 13:32:03
6137 forum posts
893 photos
I would start with decent tailstock support
Niels Abildgaard26/08/2021 14:58:15
470 forum posts
177 photos
Posted by Ady1 on 26/08/2021 13:32:03:
You must be joking
Alan Jackson26/08/2021 18:11:19
276 forum posts
149 photos
Hi Niels,
Re your narrow chuck, here is my own design narrow four jaw 6 inch chuck. The body thickness is 30mm. The jaws are guided by an oval gib that can be adjusted to eliminate slackness in the jaw guidance.
Alan
Slim bodyJaws extended
Niels Abildgaard26/08/2021 18:23:17
470 forum posts
177 photos
Posted by Alan Jackson on 26/08/2021 18:11:19:
Hi Niels,
Alan
Congratulation on work of a genius.
I have used hours to come up with something as good and failed.
How do You restrain the four jaw screw from coming out?
Edited By Niels Abildgaard on 26/08/2021 18:25:08
Edited By Niels Abildgaard on 26/08/2021 18:28:51
Alan Jackson26/08/2021 18:29:02
276 forum posts
149 photos
Hi Niels,
Thank you for your kind comments. The screws are secured by locked screws that can be reached inside the bore.
Alan
Niels Abildgaard26/08/2021 18:35:02
470 forum posts
177 photos
Posted by Alan Jackson on 26/08/2021 18:29:02:
Hi Niels,
Alan
picture or sketch please?
Alan Jackson27/08/2021 09:31:58
276 forum posts
149 photos
Hi Niels
If you zoom up on the second photo you can see the screw heads in the chuck bore.
Alan
Niels Abildgaard27/08/2021 16:14:26
470 forum posts
177 photos
Posted by Alan Jackson on 27/08/2021 09:31:58:
Hi Niels
Alan
Thank You.
Am still confused but at a higher level.
Do not bother
Niels Abildgaard29/08/2021 17:22:27
470 forum posts
177 photos
Some high resolution stills and first cutting video.Performance is not impressive.
First cut Monster Mini Lathe
Niels Abildgaard02/09/2021 16:53:58
470 forum posts
177 photos
First parting of.44mm Heavy wall pipe, C45 150 rpm.
Iscar Tang-Grip inserts 1.4 and 3mm.
Limit is belt slip so if I want to part 88mm I will have to make and fit a 215mm spindle belt disc.
180/210 parting off
somewhat better resolution can be seen here:
Parting off
Niels Abildgaard12/09/2021 11:57:01
470 forum posts
177 photos
The lathe is back in 180 version with 27 mm hole and I dared to try some parting that went very well.
Iscar TAG N2J tipand blade and blade holder from China.
200RPM and nice mild steel C45..
If the manufacturers did some very small and not expensive changes it could become a very potent hobby lathe.
Parting off chinese mini lathe
Niels Abildgaard25/06/2023 17:38:04
470 forum posts
177 photos
A scrap-ready 920 lathe is in for a surprise.
30 and 50mm hole spindle,electric leadscrew from Numobams and sewing mashine motor 1500W also from China.
If You doubleclick link You will see a demolished house in background.
Our small town are divided what comes next:
Green eccological Kindergarten or funny house with lively ladies and lathes.
Next fun house lathe?
Double clikc for better resolution
