Hopper | 21/06/2018 07:59:37 |
![]() 7881 forum posts 397 photos | Don't mess with a flimsy Dremel. You can buy a router motor with spindle and ER11 collet chuck for $30 (15 quid) on Aliexpress, shipped. **LINK** That will hold a standard 1/4" shank cutter. If you want a more powerful .500kw motor, that's an extra $20. Edited By Hopper on 21/06/2018 08:01:36 Edited By Hopper on 21/06/2018 08:02:16 |
john constable | 21/06/2018 15:11:08 |
![]() 80 forum posts 9 photos | Thanks for that last batch of posts. I'll try to answer them all in one.
re a CNC approach. I considered the idea. Seems cheap and accurate and compact. The problem is I have zero experience of stepper motors, controllers, interfaces and control software. I wouldn't completely dismiss it but the learning curve would be VERY steep. re a router motor - an excellent idea. If I go the home made route then a dremel will probably be easier but if using a lathe with a cross slide and toolpost I might well do this. Having said that, my rotary too is a 550w vonhaius dremel-compatible, so not that flimsy. re accuracy, yes i'm concerned about accuracy with the dremel on a home-made unit on multiple passes. I was hoping i could do them in one pass as my stock isn't that thick and for instance I might be able to do hollow spirals with a narrow through cutter and finish with a fluted and that kind of thing.
My preferred option so far would be would be a mini metalwork lathe if i could get the gears to give me the pitches I need (and probably with the router motor as suggested above). Its a bit expensive for me but then I'd have the joy of full lathe operations to play with. I'm just not sure theres anything available off the shelf and I'd have to be sure I could get the gearing i needed.
oh, and here's where I am with draft 1 of the home made solution... still some way to go but just so we can see we are on the same page: |
john constable | 23/06/2018 01:30:08 |
![]() 80 forum posts 9 photos | I found this while surfing. It's opened my mind up a bit more to stepper motor control rather than syncing spindle and leadscrew and customsing gears. It's still outside my skill zone but there's so much information and support out there on the topic (especially arduino control) I'm going to explore it a bit more. I think you'll find his blog interesting:
http://blog.pdxtex.com/p/router-lathe-build.html
Roderick Jenkins | 25/06/2018 10:38:25 |
![]() 2376 forum posts 800 photos | I really think your best bet for this project is a used, old style British type, metal working hobby lathe such as an early Drummond or Myford which regularly come up on ebay. Most have an 8tpi leadscrew. It really depends on the lead ( the horizontal distance between each "thread" The state of wear on the lathe is largely immaterial for your purpose and it would not need a motor - with long leads you drive the saddle using a handle on the end of the leadscrew. Just a thought, Rod |
Neil Wyatt | 25/06/2018 13:52:25 |
![]() 19226 forum posts 749 photos 86 articles | Easiest way might be a mini-lathe as you could design a new banjo with an extra slot and get it laser cut from 4mm plate. |
