Bench Grinder
MalcB05/02/2017 17:11:32
257 forum posts
35 photos
Out of interest:
Has any body stripped any of the 3 phase bench grinders to see if their motors have the option of being wired for Delta?
Malc
Nigel McBurney 105/02/2017 17:36:32
1101 forum posts
3 photos
I prefer 8 inch grinders to 6 inch grinders, with a larger wheel the hollow ground effect is less which gives a stronger edge to a tool bit. My 8 inch grinder with 3/4 in wide wheels is Warco and made in europe,is now quite old and still going strong,about 10 years ago I bought another 8 inch grinder from warco ,far eastern manufacture,not as good,vibrates a bit but it works,it has 1 1/4 inch wide wheels, this enables me to grind drills up to 2 inch dia . Machine shops in the 1950s tended to use floor standing grinders with at least 12 inch dia wheels real steady machines with rigid tool rests and never seemed to go wrong.
larry Phelan02/08/2017 09:40:05
544 forum posts
17 photos
I never use the front of the wheel when grinding drill bits or tool bits,I use the side of the wheel. Am I doing something wrong,will I be drummed out ?
larry Phelan02/08/2017 09:49:59
544 forum posts
17 photos
Just wondering,why do suppliers not want to deliver to the North of Scotland or some of the islands,are you not all part of the "U K" ? Many of them will not deliver over here either,maybe they fear being attacked by the natives ,but most of us are OK these days,although there still a few-----------------.
Tony Pratt 102/08/2017 10:05:56
2319 forum posts
13 photos
Posted by larry Phelan on 02/08/2017 09:40:05:
No Larry you aren't doing anything wrong, perceived wisdom is that you should only use the periphery of the wheel but using the side is fine if you don't put massive pressure onto it.
Tony
