Chesterman 369 height gauge
KWIL05/08/2013 15:02:02
3681 forum posts
70 photos
All you need to knowangel
Michael Gilligan05/08/2013 15:08:30
23121 forum posts
1360 photos
Posted by Stephen Bunch on 05/08/2013 14:43:49:
Chris, here they are I hope !
A wierd system. I assume anyone on MEW can access the album Chesteman 369.
SteveB
Thanks Steve
Chris Parsons05/08/2013 15:25:03
118 forum posts
37 photos
Steve, you are a gentleman!
Yes, I can see them, excellent photos - and now having seen them I think I will start again and make something a bit better than my current attempt
Looks like the end of the clamp screw pushes a sprung plate, the same as the other clamp which is a lot better than having the screw marking the 'finger' so I am going to do the same.
I have been busy the last week or two installing electrical ducting around the walls of my 'batcave' so it will be nice to get back to doing something a bit more interesting - I have put up a couple of images of this (in Odds and Sods) if you are interested...)
This is in anticipation of a bit of re-arrangement to make room for the new milling machine...
Best wishes
Chris
Edited By Chris Parsons on 05/08/2013 15:40:58
Stephen Bunch05/08/2013 16:35:56
3 forum posts
5 photos
Chris , the "wierd system" refers to the photograph uploading not to Chesterman products. The clamp requires very little screw movement as it is a push fit on the finger. How big the miller ? will it dim the lights on start-up ?
SteveB
Chris Parsons05/08/2013 20:56:37
118 forum posts
37 photos
The motor on the mill (Sieg SX3) is the same as the one on my lathe (Sieg SC4) which are both 1000w brushless - they run off a standard ring main (13 amp plug - I am in the UK, 240v supply)
The ring main and lights are not on the same circuit, the sockets in the 'batcave' are on a 32 amp circuit breaker, and I have never had it trip (so far!) This is a standard circuit in the UK - the same type of socket you would plug your television into, nothing special. If you go for an industrial milling machine (like a Bridgeport) I believe these run off a 3 phase supply and have special supply requirements but I certainly do not have the space for something like this...
It's not very likely I'll have the mill and lathe working hard at the same time - but to put it in perspective an electric radiant heater is 2.5 KW (2,500 watt) and you can run these off a 13 amp socket apparently
All the cabling is up to spec (I studied electrical engineering in college many years ago)
I am more worried about hot metal chips going down my overalls
Be lucky
Chris
Edited By Chris Parsons on 05/08/2013 21:13:06
