David-Clark 1 | 17/09/2023 11:46:41 |
![]() 271 forum posts 5 photos | Hi Nigel I did not post twice and I can't see how to delete it. |
Nigel Graham 2 | 17/09/2023 13:54:08 |
3293 forum posts 112 photos | It happens fairly often on different fora so must be some quirk of how the site works. |
JasonB | 17/09/2023 13:57:16 |
![]() 25215 forum posts 3105 photos 1 articles | More often a slow connection or fat fingers at the poster's end. |
David-Clark 1 | 17/09/2023 14:25:23 |
![]() 271 forum posts 5 photos | Hi Jasonb 1,000 gb connection so not speed. Fat fingers possibly but I usually use a stylus. |
Howard Lewis | 17/09/2023 15:10:15 |
7227 forum posts 21 photos | Purely an aside, Try finding a Tap for 6.354 mm x 1.27 mm, or 0.907 mm pitch! Or looking for 0.236 x 25.4 " one! I'll settle for 1/4 BSW or UNF, or M6 If a machine was originbnally made to Imperial (Or Metric ) dimensions, best to stick to those units. Yes, Ive come across some hybrids, 3/8 BSF at one end of a stud and 3/8 UNF at the other, or 5/16 BSF bolt with a 5/8 A/F head, but those wouldn't have beeen my choice. Yes, we quote BA sizes in Imperial, but really are Metric (O BA is 6 x 1, with succeeding sizes decreasing by a factor 0.9 ) The odd ball feature is the 47.5 degree thread form,, but that might be the Thury parentage to differ from both Whitworth, and Metric form Measuring items in units which were not used originally just makes for complications Witness film speeds in Russian Gost units rather than Scheiner or ASA DON'T mention Weston or Hurter and Driffield, or the A/F sizes for Whitworth form fasteners! Howard |
David-Clark 1 | 17/09/2023 15:20:26 |
![]() 271 forum posts 5 photos | Hi Howard, I think converting threads directly is a stupid idea and doubt that was what the original poster meant. Yes, metric dimensions would be fine but threads should be suitably selected for the jo.b in hand wether they are imperial, metric or measured in bananas. |
HOWARDT | 17/09/2023 17:51:13 |
1081 forum posts 39 photos | A design is basically imperial or metric, not both. While you can use threads of one in the other, where I use metric fasteners in my imperial engine builds, you shouldn’t convert dimensions unless you merely want to use measuring devices in the other standard. Trying to round dimension or use material sizes will create all sorts of problems with fits and clearances. Metrication or imperialisation needs to be applied creating a complete set of new working drawings with all the fits and clearances worked out to ensure a working model. |
JasonB | 17/09/2023 18:18:49 |
![]() 25215 forum posts 3105 photos 1 articles | I think this is an original Myford drawing for the spindle nose, not sure how easily those -ve figures would translate to modern H & h fits. Certainly easer to see how many thou under or over you can be than having to go looking up charts and working out what the tolerences are in microns. |
Alan Donovan | 18/09/2023 07:39:21 |
81 forum posts 41 photos | Hello. First. To follow on from JasonB’s comments on the dimensioning of Myford parts. Myford (Beeston) used a ‘metal off’ system of tolerancing for all their manufactured parts. This was to enable the engineer actually cutting the metal to have a target dimension to achieve, but if he/she went over that dimension they would almost certainly still be within tolerance. As we all understand, it is easier to remove excess metal than replace what we removed in error. Second. If I remember correctly, I think there was reference in this thread to wax(?) printing components to investment cast in metal. Would this require two CAD files? The second file to print an enlarged wax component to allow for casting shrinkage. Plus the additional metal (wax) for where machining is required. All the best to everyone. Alan
Edited By Alan Donovan on 18/09/2023 07:44:49 |
JasonB | 18/09/2023 07:50:09 |
![]() 25215 forum posts 3105 photos 1 articles | I think most people making their own patterns would print in somnething like PLA which is the usual basic filament material and then after some surface prep use that as the pattern. One or two may CNC cut the pattern. You would ideally want a STL file for printing and STP or STEP if CNC cutting with suitable allowance for shrinkage of the chosen metal, machining allowances added to all faces to be machined including draft angle, core prints added as required and then suitable core box drawings/files to form the cores in. If the part needed to be split in half then you would want two files and need to include pins/sockets to locate the two halves together. Then there would be a separate machining drawing required. |
