Herringbone Gear
noel shelley11/07/2023 16:33:30
2308 forum posts
33 photos
The double helical planetary train shown by Gary was being made by a charity and sold at the Midland expo a few years ago. I bought one, and it was fasinating, UNTIL I left it on the dashboard one day and it melted into a solid lump ! This brought home one of the short comings of some types of 3D printing materials. Noel
Howard Lewis11/07/2023 21:14:37
7227 forum posts
21 photos
If you want to see double helical (Herringbone ) gears in operation, go the The WaterWorks Museum in Hereford and look atb trhe big National gas engine.
The next dayb thastbthe engine will be operating is Sunday August 13th
duncan webster11/07/2023 21:24:52
5307 forum posts
83 photos
The brine pump at the Lion Salt Works has double herringbone gears, probably cast, but the engine is not well displayed, difficult to get a close look
Nigel Graham 211/07/2023 22:51:54
3293 forum posts
112 photos
The single or double ('herringbone' helical gear was a natural progression from 'Stepped Gears' : a set of relatively narrow spur wheels bolted together to make the full width, with each rotated slightly past its neighbour.
At the other end of the scale was the 'Knuckle Tooth' or 'Hollows and Rounds'. These profiles are simply semicircles meeting each other on their diameters. Simple and cheap to make, they were used only for slow, rough work like manual winches, because the teeth do not roll on each other but slide with a lot of friction and alternating velocities.
Grindstone Cowboy11/07/2023 23:10:58
1160 forum posts
73 photos
Herringbone gears are also used on the Anderton boat lift in Cheshire, you can see them (just) here.
Links to http://s0.geograph.org.uk/geophotos/05/00/89/5008920_d21b9ad9.jpg
Rob
duncan webster11/07/2023 23:19:38
5307 forum posts
83 photos
Not now they're not. When originally built it had a humongous hydraulic ram under each caisson, but they went rusty, so were replaced with the gears and counterweights as per Rob's link. However the new structure holding that lot up is now itself past its best, so at the latest rebuild it went back to long hydraulic ram under the caisson. My daughter-in-law's father has a summer job driving and maintain it. They counterweight gubbins is still in place, but no ropes (or weights)
Grindstone Cowboy11/07/2023 23:43:17
1160 forum posts
73 photos
Thanks Duncan, didn't realise that yes
Rob
Michael Gilligan13/07/2023 09:20:37
23121 forum posts
1360 photos
Another gem from my brother, who is currently jollying around the country:
http://www.watchetconservationsociety.co.uk/pdfs/StoatesMillInterpretationBoard.pdf
Edited By Michael Gilligan on 13/07/2023 09:23:10
