Sensitive Drills - Help with Identity and other Questions
Richard B08/07/2023 20:56:56
31 forum posts
35 photos
Not sure why the pics are not below text ?
Also the colour has not shown up well - its a very dark Blue.
Richard B.
Steve Crow09/07/2023 11:06:14
429 forum posts
268 photos
Thanks Richard, that looks very nice. I suspect it was a kit of castings as well.
I've stripped mine to its component parts, cleaned everything up and put it in a box. Surprisingly, all the bits, apart from the column, fit in a wooden wine bottle box. Chateau Rothschild of course (I got given a load)
I'm going to renovate and paint it at the same time as I do my Champion No1.
In the meantime, I'm part of the way into rehabilitating this little fellow-
I'm making a new spindle with an integral ER8 chuck running in Oilite bearings and replacing quite a few other components as well. There will be an adjustable pulley countershaft and a motor. I am aiming for something compact I can easily move around the bench.
Steve
Steve Crow09/07/2023 11:21:44
429 forum posts
268 photos
This is the idea.
The column is shortened and the table omitted for the sake of the drawings.
geoff walker 109/07/2023 16:55:20
521 forum posts
217 photos
Hi Steve,
The first 1/4" drill you asked about was covered in a series of articles in M.E.by the writer "NED".
It commenced in issue 2092 on June the 12th 1941.
It continues in 2094 and 2096.
I have those three magazines, if you would like them send me a p.m. and I'll post them to you.
The build is not complete and continues in 2098 and probably at least one more issue.
Geoff
geoff walker 109/07/2023 17:05:42
521 forum posts
217 photos
Hi again Steve
This is page 473 from 2092
Geoff
Edited By geoff walker 1 on 09/07/2023 17:13:20
geoff walker 109/07/2023 20:07:04
521 forum posts
217 photos
Is it Westbury's? ..did ?Blackgates used to do it? ..or Reeves ..I can still 'see' the line-drawn ad that used to run in ME/?MEW
Just looked up the writer called "NED", and found that it is indeed Edgar T Westbury. So yes an E.T.W. design.
Geoff
Steve Crow09/07/2023 20:41:48
429 forum posts
268 photos
Thank you Geoff, this is really interesting. I will send you a pm.
I am assuming these were pre-war castings as people might have been otherwise occupied in June 1941.
Also, the drawings have the flat belt "fast and loose" drive, as in one of the earlier posts.
Seeing it's vintage, I'm going to try to give it a sympathetic restoration.
Cheers,
Steve
Richard B10/07/2023 21:15:55
31 forum posts
35 photos
If its possible I would appreciate a scan of the articles as I could not find anything when I developed mine and did my own thing !
I would have thought a simple sensitive drill would still be a popular item for model engineers when dealing with small drills and it can be used for hand tapping (belts removed) very small taps. As I noted the only other machine I know of is the Geo Thomas Universal pillar tool.
I have also made a tapping device as a stand alone unit - again using some ideas from the Geo Thomas design
Richard B.
Richard B10/07/2023 21:21:48
31 forum posts
35 photos
This is the tapping device - can't rotate image unfortunately !
DMB10/07/2023 21:45:18
1585 forum posts
1 photos
Many years ago, Chas. Kennion supplied castings and drawings for a similar little drill. Maybe GLR/KENNIONS still do, I don't know.
Nigel Graham 210/07/2023 23:54:49
3293 forum posts
112 photos
Richard -
I think you can only rotate the image and re-save it, in a separate photo-faffer such as MS 'Photo'. It catches a lot of users out, including me a couple of times.
The millers in a printing-machine factory where I once worked, made slightly similar tapping devices, but theirs used a plate to which was screwed a pair of blocks.
The spindle with similar handle worked through one, the chuck was in the central space and the tap passed through a hole in the second block which thus acted as the work-piece thrust-face.
The base-plate was simply held in a bench-vice or the milling machine-vice.
Andrew Moyes 111/07/2023 14:34:08
158 forum posts
22 photos
There is a whole chapter on 'Modifications to "M.E." Drilling Machine' in the book 'In the Workshop' volume 1 by Duplex. Mine is the first edition published in 1949. It seems to be the Ned design as identified by others. The article runs to 24 pages.
Steve Crow16/07/2023 18:43:24
429 forum posts
268 photos
Posted by geoff walker 1 on 09/07/2023 16:55:20:
Hi Steve,
Geoff
Sorry Geoff I've tried to send you a pm but I just can't work out how to do it!
I've received and replied to them before so if you send one to me, I can get back to you.
Cheers
Steve
bernard towers17/07/2023 00:57:11
1221 forum posts
161 photos
Steve if you look at Geoffs post then underneath it is a line of choices you need the left one
