pgrbff | 16/10/2022 12:24:14 |
261 forum posts 31 photos |
So for the ignorant, 1/4" BSF? |
peak4 | 16/10/2022 12:25:45 |
![]() 2207 forum posts 210 photos | Posted by Michael Gilligan on 16/10/2022 10:17:25:
Looking at the wear on that screw, and noting Rod’s comment about BSF going tight … I wonder if the tapped hole is tapered My guess is that the plane-maker didn’t use a bottoming tap. MichaelG. . Edit: __ My own example of that plane [also purchased new] was quite poorly made in some areas Edited By Michael Gilligan on 16/10/2022 10:23:16 From the Part 1 link to the Australian pdfs I mentioned earlier; |
Howard Lewis | 16/10/2022 12:40:35 |
7227 forum posts 21 photos | My first thought, reading the comments re 1/4 BSW and M6 (MOST unlikely on a Record ) was 1/4 BSW Are you not able to make one? (No die? ) The hexagon does not matter, except to absolute purists. It is only there to rotate the screw to provide the clamping force to hold things together. At a pinch, could someone post pou a short piece of 1/4 BSF stud and a nut, so that the envelope is not too fat? Howard.
Michael Gilligan | 16/10/2022 12:55:15 |
![]() 23121 forum posts 1360 photos | Posted by Howard Lewis on 16/10/2022 12:40:35:
. Presumably a typo, Howard Your later reference to BSF is correct MichaelG. |
Michael Gilligan | 16/10/2022 13:06:48 |
![]() 23121 forum posts 1360 photos | Thanks for the quote, Bill … That makes perfect sense as what the process should have been What I was trying to imply was that maybe manufacturing shortcuts were being made; in the interests of economy, or just plain idleness. [e.g. The ‘shims’ for the nose of mine were pretty rough around the edges] MichaelG. Edited By Michael Gilligan on 16/10/2022 13:07:33 |
pgrbff | 16/10/2022 14:20:57 |
261 forum posts 31 photos | Posted by Howard Lewis on 16/10/2022 12:40:35:
I have ordered a 3/8" by 1/4"BSF screw from the Bay, sent to my sister-in-law. Just have to wait now. |
old mart | 16/10/2022 16:58:10 |
4655 forum posts 304 photos | Some of the old makers made non standard proprietry threads specifically to force users to buy their spare parts. This is common with the large indexable insert producers, yuo buy a nice toolholder and find that only the same make of inserts will fit. |
duncan webster | 16/10/2022 19:34:43 |
5307 forum posts 83 photos | I've read somewhere that the Royal Navy used non standard threads so that if a warship fell into enemy hands they wouldn't be able to maintain it. Theses foreign chappies can't make nuts and bolts of course. |
File Handle | 17/10/2022 12:53:02 |
250 forum posts | Posted by peak4 on 15/10/2022 13:13:05:
One of the above links to the article about Record planes seems to be dodgy; this one works OK Part 2 amongst other things , refers specifically to the No.12-20 thread Thanks for sharing Bill, the 2 parts make interesting reading. |
Grindstone Cowboy | 17/10/2022 18:11:06 |
1160 forum posts 73 photos | Posted by duncan webster on 16/10/2022 19:34:43:
I've read somewhere that the Royal Navy used non standard threads so that if a warship fell into enemy hands they wouldn't be able to maintain it. Theses foreign chappies can't make nuts and bolts of course. I understand the Brown Bess musket was made a larger calibre than the contemporary French service musket so we could use their ammunition, but they couldn't use ours. Rob |
Rod Renshaw | 17/10/2022 20:58:56 |
438 forum posts 2 photos | I heard the the Royal Navy used no screws smaller than half inch diameter as the matelows would accidently twist the heads off anything smaller. It was probably a rumour put about by the army. |
